LOST(or I think it is): system-settings-merge.menu
    I found that my systems settings were crashing so I went to look for a solution and I found snowhog's post : http://kubuntuforums.net/forums/inde...opic=3088490.0
    sudo mv /etc/xdg/menus/kde-applications-merged/system-settings-merge.menu /etc/xdg/menus/applications-merged/system-settings-merge.menu
    I copied as per instructions but I didn't check that I copied correctly.... infact, I didn't add "system-settings-merge.menu" at the end. now I can't find the file anymore...
    Can anyone help me?
    thanks
    crl6904
    Re: LOST(or I think it is): system-settings-merge.menu
    Hmmm. Tsk, tsk. :P Read twice, copy once.
    Open a console and type:
    cd /
    sudo find -name system-settings-merge.menu
    If it is to be found, this will tell you were you put it.
      lost without a trace....
