How do you remove entries from System Services?
    /var/log/boot.log
    Sat Nov 17 09:09:26 2007: * Starting VirtualBox kernel module vboxdrv ^[[80G FATAL: Module vboxdrv not found.
    Sat Nov 17 09:09:26 2007: ^[[31m*^[[39;49m Modprobe vboxdrv failed. Please use 'dmesg' to find out why.
    Sat Nov 17 09:09:26 2007: Starting VirtualBox host networking...done.
    System Settings | System Services
    vbesave - Start at Boot Yes not running
    vboxdrv - Start at Boot Yes not running
    vboxnet - Start at Boot Yes not running
    I changed the above to reflect "Start at Boot" No and I don't get the error reflected above anymore. But, how do you remove these entries so they aren't listed in System Services? VirtualBox had been installed, then removed (installed VMware Player instead).
    Re: How do you remove entries from System Services?
    Maybe:
    sudo dpkg -P --force-all virtualbox-ose
    man dpkg
    -P or --purge removes everything, including configuration files.
    --force-all: Turns on (or off) all force options.
    hmm - maybe first:
    --no-act | --dry-run | --simulate
    Do everything which is supposed to be done, but don't write any changes. This is used to see what would happen with the specified action, without actually modifying anything.
    And/or
    sudo update-rc.d -f virtualbox-ose remove
    man update-rc.d
    update-rc.d - install and remove System-V style init script links
    NAME
    SYNOPSIS
    update-rc.d [-n] [-f] name remove
    -f Force removal of symlinks even if /etc/init.d/name still exists.
    -n Don’t do anything, just show what we would do.
    You could also check /etc/init.d/. Is there virtualbox-ose or/and vbox scripts ?
    From Unix Manual Page for init.d
    http://www.scit.wlv.ac.uk/cgi-bin/mansec?4+init.d
    /etc/init.d is a directory containing initialization and
    termination scripts for changing init states. These scripts
    are linked when appropriate to files in the rc?.d direc-
    tories, where `?' is a single character corresponding to the
    init state. See init(1M) for definitions of the states.
    Before you edit, BACKUP !
    Why there are dead links ?
    2. Thread: Lost Information
      Thanks Rog! That was where they were.
