Was wondering if anyone is having the same problem as me and has fixed it or heard of a fix. Basically when I delete something it will go to the recycle bin and the icon will change to a full icon as it should. However when I clock on the icon to open the menu and click Empty Recycle Bin, this button is greyed out. Sometimes it is greyed and sometimes it is not. This seems very random, so any ideas on how to fix this. Sometimes I'll just delete a few more files and eventually it will let me click empty again. And yes I am sure that it has something in it.
Recycle Bin Bug
Re: Recycle Bin Bug
Don't know 'why,' but I've had it happen at least twice. If you find that it simply won't reactivate the "Empty Trash Bin", you can fix it. In Konqueror, browse to:
~/.local/share/Trash
Click on the files folder. Press Ctrl+A to select all and right-click and choose delete.
Do the same with the info folder.
The Trash Bin will be emptied, and the next time you put trash into it, you should have the ability to Empty Trash Bin again.Windows no longer obstructs my view.
Re: Recycle Bin Bug
You delete the contents of the folders.Windows no longer obstructs my view.
Re: Recycle Bin Bug
Originally posted by GoeroeboeroeI have this sometimes. I just open recycle bin by rightclicking on it. Select all. Pres Shift+del: everything's gone and it works again. Far easier than opening Konqueror etc.Windows no longer obstructs my view.
