FUSE group - what is it really for?
    First, I do have read/write access to my NTFS Windoze Vista partition. I did so with the installation of the ntfs-3g package and changing ntfs to ntfs-3g in the appropriate entry in my fstab.
    That said, though, I have noted any number of posts saying you should have FUSE added to your secondary user groups. I don't have it, and as said, I have full read/write access to my NTFS partition. So, then, what exactly does the FUSE group do?
    Re: FUSE group - what is it really for?
    Nothing for you Snowhog, apparently!
    It was required in Feisty and Edgy, to write to the NTFS partition. It may be non-essential in Gutsy -- I haven't experimented with it (yet).
      Originally posted by dibl
      It was required in Feisty ...
      But I'm running Feisty. So ......
        OK, I give up!
        Here's the background:
        http://fuse.sourceforge.net/
        http://www.linuxjournal.com/article/8904
        http://linuxgazette.net/134/appaiah.html
        If it doesn't help you, don't use it!
