I'm having a slight conundrum. You see I have a lightish blue task bar/panel thinggi and when using a different window the minimized or out of focus window's text becomes gray. This isnt a huge problem since i can normaly make out what they are but would be nice to tweak the color a bit. How do i do this?
changing color on unfocused window's text
Re: changing color on unfocused window's text
No I'm not that dumb lol. I do not mean inactive window border text (which i could care less what color it is) but the text that appears on the main program bar on the buttom of your screen. When a window is innactive there the text turns gray (hard to read) and as of yet have not found a color control in the color control center that changes it.
Originally posted by UnicornRider[Alt][F2] kcontrol > Desktop | Taskbar > Inactive Task Text Color (?)
Possibly:
[Alt][F2] kcontrol > Desktop | Appearance & Themes | Colors
Click the dropdown button under Widget Color and select Inactive Window Text then click on the color bar just below it. That opens a color panel that you can choose the color from.Windows no longer obstruct my view.
Originally posted by jbaerbockOriginally posted by UnicornRider[Alt][F2] kcontrol > Desktop | Taskbar > Inactive Task Text Color (?)
Originally posted by kubicle[This option is available on kde 3.5.7, I take it you're using an older version?Windows no longer obstruct my view.
Originally posted by jbaerbock--Just checked and I have 3.5.6 how can I upgrade safely?--
http://kubuntu.org/announcements/kde-357.php
Originally posted by SnowhogHmm. This is interesting. I too, have version 3.5.6 (when checking Help on KControl). Checked Adept for package kde. Mine is identified as not installed. But, it is a metapackage, and I am running KDE as my desktop manager. If I remember correctly, when you perform a full install from the Kubutnu Feisty Fawn LiveCD, the kde metapackage isn't used, instead, individual components are installed. That begs the question: Are there packages that the kde metapackage would install, that the LiveCD does not? How would one know?
Originally posted by jbaerbockStill is no inactive windows test, only inactive window handle, and inactive title text seem to be the only ones it could be.
Also remember to restart kde after upgrading.
