Back when I used Ubuntu I installed IE4Linux which installed IE 6.0 for me on linux. Now then I could run zone.com games fine. They use activeX controls which I can only get on a browser by using IE for Linux. However at the moment I am getting error saying my security setting are not allowing activeX controls to run. This is BS because my setting are lowest possible with all the activeX controls allowed to run automaticaly. Anyone know the problem and how to fix it? Thanks.
IE4Linux ActiveX problems...
4 GB Ram
Kubuntu 18.10
Re: IE4Linux ActiveX problems...
Solved!
I was changing all security settings myself and for some reason this did nothing. So all I did to fix it was to slide every security setting bar down to low and it worked fine. No idea why I couldn't make it work with custom settings though.
