Lookin For Good K-Menu and Dock
    Hey all...
    Looking to try out a different K-Menu and some sort of a Dock (similar to a Mac Desktop). Can anyone suggest any good ones on the KDE-Look site (or others)?
    Currently I'm not using a Dock and I had thought that one would be available in the Adept Installer - but I don't really know where it would be located and searching for things like "Application Dock" didn't turn anything up.
    Anyhew, just looking to spice it up a bit and try some different features. Thanks all!
    L.
    Re: Lookin For Good K-Menu and Dock
    If you want to change Kmenu themes & change Kmenu start button try KBFX. You can install it through Adept.
    Use this to get themes & buttons
    http://www.kde-look.org/index.php?xc...55240d3080c57a
    http://www.kbfx.org/
    Registered Linux User #418555<br />Kubuntu User #9254<br /><br />aptosid 2010-01 Xfce / aptosid 2010-01 KDE-Lite<br />Debian Wheezy Xfce / Kubuntu 10.04<br />aptosid 2011-01 Xfce / aptosid 2011-01 KDE-Lite<br />Debian Testing Gnome<br />Debian Sid Gnome<br />Epidemic 3.2<br />ALL pulseaudio free by default
      Kooldock, KXDocker, KSmoothdock, and Kiba-dock (not a KDE app, despite the name) are all OS X dock-types. The first two are available from the repositories.
      Jucato&#39;s Data Core
        Any other Docs that AREN'T OS-X looking... now that I'm on the hunt, I'm starting to think the community has come up with something better
        L.
          Tastymenu:
          http://www.kde-apps.org/content/show...?content=41866
          is a nice alernative to the default K menu.
          It is in the repos and you can get it on your panel by right clicking on your panel -> add applet->tastymenu. There are lots of configs to play with as well.
          4 GB Ram
          Kubuntu 18.10
