Public keys (whatever they are!)
    Hi.
    I'm playing with 'qemulator' and 'qemu' at the moment (and not doing very well) but the question relates to public key/s.
    I followed the directions on the 'Qemulator' site for adding their repositories to Synaptic. There was also a mention of adding a public key so I followed those instructions too but got the following error on Synaptic
    An error occurred
    the following details provided:
    W:GPG error: http://www.uv.es feisty Release:
    The following signatures could not be verified because the public key could not be verified because the public key is not available:
    NO PUBKEY 5D530DEA0ICCB361
    I had previously run:
    wget http://www.uv.es/cuan/repos/532190AF.gpg -0- | sudo apt-key add -
    This did something but the cursor did not revert to the prompt!
    So - bearing in mind I am still in 'novice' mode - what is going on?
    Any thoughts please?
    Thks
    Celeron CPU G1610@2.60GHz x 2
    GeForce 8400 GS/PCle/SSE2
    Kubuntu 14.04 - 64 bit Linux - KDE 4.13.0
    Re: Public keys (whatever they are!)
    http://www.penguin.ch/dokuwiki/doku....ecured_updates
      How on earth do you know where to find this stuff - Amazing!
      Working on it now - thanks VM
      Paul.
        Let me put it this way: working "against all odds" for several years (with so-called dangerous horses, but that's not the point) teached me a lot of things, amongst others how to search and find solutions to so-called unsolvable problems ...
          Hi.
          I've input the commands noted on the link using both the 'key' quoted on the Qemulator site and the key that came up in the original error on Synaptic. Can anyone tell me what is (am I doing) wrong as the system responds with:
          $ sudo gpg --keyserver pgp.mit.edu --recv-key 532190AF
          gpg: requesting key 532190AF from hkp server pgp.mit.edu
          gpgkeys: key 532190AF not found on keyserver
          gpg: no valid OpenPGP data found.
          gpg: Total number processed: 0
          Thanks all.
            key [...] not found on keyserver
            You may ask the guy in charge of the package to either tell you to which pgp server he has published the key he is using or make available an unsigned package.
              Thanks.
              I shall do just that and post the response (I'll also double check I aint missed sumink on his website!!)
