ddclient for dyndns.org
    Hi all,
    Follwing along in the http://ddclient.sourceforge.net/#install instructions, the process of installing ddclient seems easy enough.
    However, I can't get the process to actually kick off using the command:
    /usr/sbin/ddclient start
    and where is the startup scripts location in kubuntu 5.10
    I'm looking for something comparable to rc.d files or ~/.xinitrc
    but nothing is surfacing...expect autostart, which isn't what I really want
    Anyone out there in the same boat?
    Re: ddclient for dyndns.org
    I used to use the 'ole ddclient/dyndns.org combo a while back and it worked like a charm.  I haven't used it in a year though.  I'll see what I can find out for ya...
      Thanks skoal, I'd really appreciate that. I think I'm corssing streams somewhere...not exactly a seasoned kubuntu pro quite yet...still getting the lay of the land.
      If anything turns up...
