Wireless card D-link
    Hi
    I decide to move from windows XP to kubuntu the installation was very easy
    But I have one problem (for now) my wireless card is in Disable mode and when I'm try to Enable he came back immediately to Disable
    I'm not sure that kubuntu recognize the card correctly,
    Please advice
    BR,
    Re: Wireless card D-link
    hi,
    What version of kubuntu you're using ? Feisty or Edgy ?
    I think you should try feisty (7.04) as it has better hardware support.
