How was your upgrade
    I just completed a clean install of Feisty and found that some of the issues that I had to deal with when I installed Edgy were no longer a problem. Did others also find this or were most peoples edgy install issues still present in Feisty.
    0
    Never had a problem installing either
    0%
    0
    Had issues in Edgy, but none with Feisty
    0%
    0
    Had issues with Feisty, but less than with edgy
    0%
    0
    Same problems with Edgy and Feisty
    0%
    0
    Had more problems with Feisty
    0%
    0
    Re: How was your upgrade
    I found that for the most part the upgrade was just like my first install of Edgy, all my 'special' hardware needed to be configured so it performed properly but out of the box it all worked to some extent. A few things i did notice:
    - ATI graphics and widescreen monitor needed the same steps to fix
    - NTFS read/write was 1000x easier to setup using the NTFS config tool
    - Media keyboard now worked with all the special keys (play, pause etc)
    - Programs seemed to load faster and fonts looked better (personal opinion no idea if this is true)
    I am looking forward to even more pleasant surprises as i continue to use the new version.
