I'm attempting to add the Beryl interface to Kubuntu 6.10 and I'm having a few problems. First, I should probably say that I'm a complete newbie, so I may be screwing this up all together. In order to use the Beryl interface I need to have OpenGL and 3d Video Acceleration enabled. Since it's not already enabled on nVidia drivers, I went to install the drivers, after which I went to enable 3d acceleration:
william@william-desktop:~$ sudo nvidia-glx-config enable
Error: your X configuration has been altered.
This script cannot proceed automatically. If you believe that this
not correct, you can update the md5sum entry executing the following
command:
md5sum /etc/X11/xorg.conf | sudo tee /var/lib/x11/xorg.conf.md5sum
otherwise edit manually /etc/X11/xorg.conf to change the Driver section
from nv to nvidia.
william@william-desktop:~$ glxinfo | grep rendering
Xlib: extension "GLX" missing on display ":0.0".
Error: couldn't find RGB GLX visual
I'm not sure what I'm doing wrong here, because it seems that 3d Acceleration is still not enabled. Any help will be greatful, remember I'm a newbie, so explain it fully if possible, or if you have another method for installing Beryl on kubuntu.
command:
from nv to nvidia.
