[Resolved]Perl Module (XML::Xpath)
    Hi
    I'm using Kubuntu Edgy and trying to install some perl module named XML::Xpath.
    I used it before and i love it.
    But it seems I have some trouble running it on Kubuntu.
    I installed it via apt, via cpan, and even manually and I always get :
    yuuki@yuuki:~/bao$ perl script.pl
    Can't locate XML/Xpath.pm in @INC (@INC contains: /etc/perl /usr/local/lib/perl/5.8.8 /usr/local/share/perl/5.8.8 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.8 /usr/share/perl/5.8 /usr/local/lib/site_perl .) at script.pl line 2.
    BEGIN failed--compilation aborted at script.pl line 2.
    Line 1 is the usually "!#whereIsPerl" line
    Line 2 is the "use XML::Xpath;" line
    This script works fine on other linux system.
    I checked the path in the error, and the module is there.
    yuuki@yuuki:/usr/share/perl5/XML$ ls -l
    total 24
    drwxr-xr-x 3 root root 4096 2007-03-18 03:27 XPath
    -rw-r--r-- 1 root root 17113 2003-01-26 20:33 XPath.pm
    I dont know why its not working... I tried running the thing with su, changed mod with some devils number... always the same error.
    Any Idea?
    Re: Perl Module (XML::Xpath)
    Maybe you should add /usr/share/perl5/XML to the contents of @INC ... :P
      still not working.
      Its looking for XML/Xpath.pm in the path defined in @INC. As you can see, the /usr/share/perl5 is in it,
      and /usr/share/perl5/XML/Xpath.pm is installed.
      I tried to add use lib qw(/usr/share/perl5/XML/Xpath.pm); in my script.
      It works but then, i have another error:
      yuuki@yuuki:~/bao$ perl script.pl 19-00-00
      Can't locate object method "new" via package "XML::XPath" (perhaps you forgot to load "XML::XPath"?) at script.pl line 28.
      yuuki@yuuki:~/bao$
      This is a XML::Xpath fonction and it acts like i didnt include it
      Tried to use another perl module like XML:OM and it work fine. DOM and Xpath are both in the right folder, with the same rights. I really don't understand why perl cant locate Xpath...
        May sound silly, but if Python were case-sensitive, referring to "XPath" and "Xpath" alternately, would make me think of a typo ... (?)
          sorry i already resolved the problem
          and yes, in fact I used older version of Xpath.
          the new one is XPath with maj P....
          Hate those little stupid errors that drive you crazy
          thx for the help
