Update:
"KleanUp v0.3.01b"(March, 10th, 2007)
Download KleanUp and FAQ: http://www.geocities.com/lightzook/KleanUp.html
KleanUp v0.3.01b Change Log:
Major Updates:
-Wipe is now installed by KleanUp into /usr/local/bin using the source pre-compiled by me.
--Wipe is now called by "wipe [options] [file]"
-RAM disk shred option has been commented out and should not be used for the time being
--I am hoping to fix the RAM shred soon
-Size of mounted OS free space _before_ and _after_ KleanUp runs is now printed to the file "Before_After.txt"
--The file is located at ~/KleanUp/results/Before_After.txt
--Read the file for more information
--Useful to find amount space recovered by KleanUp
-The mounted OS File System type and it's configuration is now printed to the file "File_System.txt"
--The file is located at ~/KleanUp/results/File_System.txt
--Useful for evaluating the level of secure data removal in regards to the file system
Minor Updates:
-When shredding the Free space file "scrub" Wipe uses _one_ known pass (zero).
--I have reduced the number of passes because they are redundant (to Scrub) and the extra passes take a long time
-Cleaned up the code a good bit and improved explanations (hopefully)
-Fixed an issue where the /root/.kde/cache-*-desktop/ not being shredded
-Updated the "Read_Me.txt" to reflect relevent info in this file and improved explanations (hopefully)
-Created this Change_Log.txt
News:
-KleanUp has a new home on Sourceforge at https://sourceforge.net/projects/kleanup !
--I haven't done much yet, I'll post when the project pages are ready...for now Geocities will be home
Benifits of KleanUp:
Using KleanUp and the packages KleanUp offers to install will easily free up at least a few hundred MB's of space and help you retain a lot of privacy.
Preamble:
I wrote two scripts (KleanUp.sh and KU_root.sh) to automate the process of removing old, orphaned, unused, broken, bloated and unneeded file types and directories from Kubuntu (specifically 6.10). KleanUP automatically and securely shreds files, directories, Swap partition, Free space, RAM disk, etc, etc.
In short, KleanUp started as tool to reduce the size of my install . But then it turned into a much more robust and secure tool which still reduces the size of an installed system but also offers much more. I couldn't find a tool on Linux/Kubuntu which would automatically and securely shred directories, securely clear files (eg. 'konq_history"), shred data, Swap, Free space, Slack, etc, etc. There a quite a few shredding tools for Linux (eg. Shred, Wipe, THC secure_delete, DiskScrub, etc, etc) but none automatically shred data which can compromise your privacy...so I wrote KleanUp which in it's current version uses 'Scrub' and Wipe.
Read_Me.txt:
Major Updates:
Minor Updates:
News:
Preamble:
Read_Me.txt:
Read_Me version 0.2.03
March, 13th, 2007
KleanUp v0.3.01b
Written by 'lightzoo'
Homepage: https://www.sourceforge
Email: lightzooK@yahoo.com
Thread: http://kubuntuforums.net/forums/inde...opic=3080222.0
GnuGP Public Key: See end of file
KleanUp
- - ---> Files:
Files included in /KleanUp-0.3.01b/:
KleanUp.sh = The main and base script of KleanUp
KU_after.sh = The script which computes and prints the total size of Free space, etc after KleanUp runs
KU_before.sh = The script which computes and prints the total size of Free space, etc before KleanUp runs
KU_FS.sh = The script which prints the type of FS and the FS's configuration for the mounted OS.
KU_root.sh = The script section of KleanUp which shreds data in non-/home/ directories, Swap, Free space, etc.
Files included in /KleanUp-0.3.01b/src/Wipe_v2.3.0-cvs/:
wipe-wip-20050509.tar.bz2 = Source files for Wipe v.2.3.0-cvs
wipe-wip-20050509.tar.bz2.sig = Author's signature for source files of Wipe
wipe-2.3.0-cvs_compiled_src.tar.gz = Pre-compied source files to facilitate installation of Wipe
wipe-2.3.0-cvs_compiled_src.tar.gz.sig = My signature for the pre-compile source file of Wipe
Files included in /KleanUp-0.3.01b/results/:
Before_After.txt = Total amount of Free space, Swap, etc before and after running KleanUp, usefull to know amount of Free space recovered.
File_System.txt = Shows the type of FS (eg. ext3) and it's configuration, important to evaluate possible level of data shredding.
- - ---> Usage:
1-Close _all_ non-essential applications.
2-Extract the file "KleanUp-0.3.01b.tar.gz"
3-Enter the newly extracted folder "/KleanUp-0.3.01b/"
4-Open a terminal and run this command: sh ./KleanUp.sh
5-KleanUp creates directory tree "~/KleanUp/..."
6-KleanUp files are 'cp'd into ~/KleanUp/
7-KleanUp runs, shredding files, folders, FS, etc
8-_DO NOT_ interrupt the shredding process
9-KleanUp exits and the computer reboots
10-Manually delete KleanUp-0.3.01b.tar.gz and it's extracted folder
11-In the future run KleanUp with:
cd ~/KleanUp
sh ./KleanUp.sh
- - ---> General Information:
KleanUp was written using Kubuntu 6.10 Edgy and I have only tested in on Kubuntu 6.10.
KleanUp does not address the issue of file slack space (inodes). When you wipe Free space with KleanUp only unallocated space will be wiped, file slack in allocated space will not be wiped.
Software wiping is more effective on modern, high-speed hard disks than on outdated (e.g., RLL) units, Zip, and floppy disks. However, there is *NO* software-based substitute for physical disk destruction. Anyone who believes that a software wipe utility can be 100% foolproof is mistaken. Software wipe tools can be better or worse, but none is perfect.
Journaling filesystems (eg. ext3) cannot be wiped with 100% accuracy and confidence due to the nature of JFS meta-data (used on current Linux Kernels). For dependable and accurate data sanitation use an ext2 filesystem with a large amount of RAM (+512) and _disable_ the Swap permanently. For more information regarding the limitations and security holes of JFS see: http://en.wikipedia.org/wiki/Shreddi...g_file_systems
For more information and a list of links see the KleanUP FAQ and downloads section on the KleanUp website:
http://www.geocities/lightzooK/KleanUp.html
- - ---> Shredding algorithm details:
>Wipe v2.3.0-cvs<
KleanUP uses Wipe to shred files (using wildcards and recursive shredding), entire directories and Swap using the following configuration:
wipe -Z[<d/D>][<n/N>]tv[<a/A>]kf<r>O -S512 -C4096 -l1 -x[<1><3>] -p1
- - -Legend-
(Some of these settings are default but I thought it's useful to show all settings used, defult and KleanUp's settings.)
Z = normal passes
d = delete file
D = do not delete file, only shred contents of file
n = delete special file
N = do not delete special file
t = enable static passes
v = very verbose
a = write until out of space
A = don't write until out of space
k = lock files
f = force, override interaction
r = recursive shredding
O = write to file
S512 = block device sector size is 512bytes
C4096 = chunk size is 4096kb
l1 = secure level 1 (I assume this means using /dev/urandom/ for pseudorandom data generation--not as secure as AES which Scrub uses)
x1 = 1 pseudoranodm pass _per_ one wipe pass (see below)
x3 = 3 pseudorandom passes _per_ one wipe pass (see next)
p1 = wipe file one time with known <n> pattern ([x]<3> combined with [p]<1> is a total of 4 passes per file, known pattern pass is last.)
*After a file (or it's contents) is shredded it's directory entry is unlinked and shredded, the file is renamed multiple times then removed by Wipe and finally KleanUp runs 'sync'. Files which are not to be removed have their contents shredded but the directory link and file names are not shredded.
*Wipe utilizes a write barrier between each pass.
*I have compiled Wipe from the cvs snapshot release "Wipe-2.3.0-cvs" as "wipe" in /KleanUp-0.3.01b/src/Wipe_v2.3.0-cvs/. There are _MANY_ improvements over version-0.20.2 which is the currently available .deb package.
>Scrub v1.8<
Scrub uses a shredding algorithm which sufficiently meets the NNSA Policy Letter NAP-14.x (see reference below) for sanitizing removable
and non-removable hard disks. This requires overwriting all locations with a pseudorandom pattern twice (AES pseudorandom) and then with a known pattern.
*After a file's (_non_wildcard and _non_recursive shredding) contents is shredded it's directory entry is unlinked and shredded. The file is then renamed multiple times with the final name of "jd92n". Then the file is shredded and removed by Wipe (see above) and finally KleanUp runs 'sync'. Files which are not to be removed (eg. .bash_history) have their contents shredded but the directory and file name are not shredded and Wipe is not called.
*Scrub utilizes a write barrier between each pass.
*Free Space is filled until an error occurs using a self-expanding file ("scrub") containing pseudorandom data (AES pseudorandom) then the file is shredded by Scrub and finally removed by Wipe. Note: When shredding the Free space file "scrub" Wipe uses _one_ pseudorandom pass and _one_ known pass.
*The NNSA algorithm is reasonable and recommended for sanitizing modern PRML/EPRML encoded disk devices.
Please refer to the NNSA document for additional constraints:
NNSA Policy Letter: NAP-14.x, "Clearing, Sanitizing, and Destroying Information System Storage Media, Memory Devices, and other Related Hardware", Unpublished Draft, 2005
>dd<
KleanUp executes three 'dd' passes of pseudorandom data from /dev/urandom/ and a final 'dd' pass of zero from /dev/zero/ with 'sync' between passes on the Swap partition.
Future releases of KleanUp will use Wipe or Scrub to shred the Swap...or you could shred it and turn it off for good (recommended).
- - ---> KleanUp Operations:
Only files present on a defult install of Kubuntu will be shredded (ex. Firefox files are not shredded). KleanUp assumes you do _not_ run programs such as 'Kaffenine' or surf the web with Konqueror as Superuser:
>Misc 1<
+Calculate and print size of mounted OS and file systems before and after running KleanUp
+Print the FS and configuration used by the mounted OS
>/home/<
+Clear the bash history in ~/...
+Clear the .xsession-errors file in ~/...
+Shred HTTP/S files in ~/cache-*-desktop/...
+Shred Kaffenine's list of viewed videos (playlists) in ~/...
+Shred 'kconf_update.log' in ~/...
+Shred the Konqueror cookie file in ~/...
+Shred the file 'formcompletions' in ~/...
+Shred files/folders in 'Recent Documents' in ~/...
+Shred file 'konq_history' in ~/...
+Shred file 'secret-cookie' in ~/...
+Shred Konqueroer crash log file in ~/...
+Shred the Trash Can in ~/...
+Shred thumbnails in ~/...
+Shred the directory '~/Examples/'...
+Shred Konqueror URL/location bar and other web traces
>Packages/modules< (KleanUp offers to download and install with [y/n] prompt)
+Download and install Alien
+Download and install Scrub (.rpm)
+Download and install Wipe
+Download and install Deborphan
+Download and install Kleansweep
+Download and install Localepurge
+Load the KDE Kontrol Privacy module
++Clear clipboard contents (using KDE Kontrol Privacy Module, _not_ Scrub)
++Clear run command history (using KDE Kontrol Privacy Module, _not_ Scrub)
+Remove packages that _were_ dependencies
+Remove downloaded and partially downloaded package files (non-locked)...
+Remove old package files that can on longer be downloaded (locked)...
>/root/<
+Clear bash history in /root/...
+Shred HTTP/S files in /root/...
+Shred KDE update log file in /root/...
+Shred files/directories in 'Recent Documents' in /root/...
+Shred Konqueror crash log file in /root/...
+Shred Trash Can in /root/...
+Shred all thumbnails in /root/...
+Shred Konqueror crash log in /tmp/...
+Shred 'secret-cookie' in /tmp/...
+Shred 'example-content' directory in /usr/...
+Shred all logs in /var/log/...
+Shred HTTP/S files in /var/...
>Partitions, File Systems, etc<
+Shred Swap partition with three passes of pseudorandom data from /dev/urandom/ and a final pass of known zero's from /dev/zero/.
++Between passes KleanUp executes the "sync" command
+Shred Free Space with Scrub (see above)
>Misc 2<
+Restart computer
--Future versions of KleanUp (To-Do):
--Shred File Slack Space (inodes)
--Shred the Swap partition with Wipe (if possible)
--Use Scrub/Wipe to shred clipboard and run command history
--Add capital and lower case [y/n] support, now KleanUp only supports _lower_ case.
--Initiate shutdown then stall (eg. -h), possibly with "Kshutdown". As so:
----Reboot > stall > run commands (shred Swap, Free, RAM) > When KleanUp finishes running the computer is automatically restarted.
March, 13th, 2007
KleanUp v0.3.01b
KleanUp
- - ---> Files:
- - ---> Usage:
cd ~/KleanUp
sh ./KleanUp.sh
>Wipe v2.3.0-cvs<
- - -Legend-
Z = normal passes
d = delete file
v = very verbose
k = lock files
O = write to file
>Scrub v1.8<
>dd<
>Misc 1<
>/home/<
>/root/<
>Misc 2<
+Restart computer
