OpenGL problem in Kubuntu
    Dear Kubuntu users,
    I am using kubuntu and now it seems that my OpenGL is not working. If I issue the "glxinfo" command I am getting the following,
    russell@Newton:~$ glxinfo
    name of display: :0.0
    Error: couldn't find RGB GLX visual
    visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav
    id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat
    0x22 16 tc 0 -1 0 r y . -1 -1 0 0 0 16 0 0 0 0 0 0 0 None
    0x23 16 tc 0 -1 0 r y . -1 -1 0 0 0 16 8 16 16 16 0 0 0 None
    0x24 16 tc 0 -1 0 r y . -1 -1 8 0 0 16 8 16 16 16 16 0 0 None
    0x25 16 tc 0 -1 0 r . . -1 -1 8 0 0 16 8 16 16 16 16 0 0 None
    I don't know what is really wrong in my set up. It would be of great help if someone could help to solve this problem. Many thanks in advance.
    Re: OpenGL problem in Kubuntu
    Do you have some more info? What kind of VGA kaart youre using.
      Have you checked Xorg.0.log (/var/log/Xorg.0.log) ? Also: System > System Log Viewer > Display the X.org log.
      Any (WW) warnings or (EE) errors ?
      Before you edit, BACKUP !
      Why there are dead links ?
      2. Thread: Lost Information
        If you have an nVidia or ATI card, look for a program called "envy" sorry, don't have the link handy, but you could probably find it searching the forums.
        Basically, it automatically grabs and configures the correct driver from the manufacturer.
        works pretty good.
        ...and so, the frog hopped away and the princess wiped the frog-slime from her lips, THE END.
          http://albertomilone.com/nvidia_scripts1.html
