Yes, folks, you heard correctly. I am one of the lucky few that unplugged myself from the 3d Desktop world, also known as Beryl, and stand before you with only minor cuts and scrapes. I walked away and live to tell my story. Gosh, I am like one of those shark attack survivors.
What's that? Some user in the third row just yelled "Who would do such a thing and why?" I will tell you. Because after trying several distros (yes, I test a lot of them...and not because I don't have a life, really), Beryl seems to run the slowest under Ubuntu/Kubuntu than most distros out there. I have no idea why this is, but it does. After just turning it off, there is definitely a speed increase when applications and windows open, and for some reason, webpages download. Go ahead...try it. I know, it's even hard to turn it off for a moment, the hand starts to shake.
Here is a free tip. I turned on the KDE built in shadows (turned off the transparency features, but they are there if you want them) and it looks and appears just like Beryl's windows with shadows. Who knew?
What I gain is still tons of speed in the way applications behave. What I loose, however, are wobbly windows....ewww, can't live without those. A 3D cube I used once to impress a friend, who was only mildly impressed. I hate that. By the way, it was faster to just click the KDE pager that lives in the taskbar than to use the 3D cube *sigh*. The wondrous Jeannie (or is that Gennie?) effect had to go...never really liked that one. Most of the other stuff..um, never really utilized..at all...zilch..nada. Oh wait, I did accidental touch the side of the screen with my mouse and the windows all minimized so I can choose the one that I wanted....by accident. Did you get that part? I could never figure out how to make it work manually. I just thought it was a rare treat and accepted my good fortune.
Seriously, I am much happier without Beryl, because speed is far more important to me. Plus, Beryl did not always start-up and shutdown as smoothly as it did under Gnome. Some apps would have "issues" with it. Lets just leave it at that. Beryl needs to have more substance. It is shallow, superficial and gives bad bloat.
What I don't have is a support buddy, you know, in case I get the itch to light up and wobble my window. Anyone else fed up with Beryl and need support walking away?
