Still looking for a way to install and run EXE's in KDE Neon.
I decided to try ReactOS or even an old WinXP or 7 in a VM.
I looked into Discover to find it offered something called qemu-Virgil, which turned out to be leap into the past, which didn't run. Why have a GUI when you have to do everything on the CLI? Six out of the seven comments called it a piece of trash. I agree.
Then I looked into what was availabe through muon. There was libvirt-manager. I installed it and its dependencies.
I found its icon in System and clicked it. It couldn't find libvertd, the daemon.
Muon showed it as being installed.
systemctl start libvirtd
systemctl status libvirtd
got it running and showed it running, and the virtual machine manager opened the GUI as it should have.
Now to find and install a Windows VM.
) no longer an option for running Windows EXEs? Serious question because I don't run any Windows software on my systems. Has Wine been maintained?
le:StdMarshalImpl_MarshalInterface Failed to create ifstub, hr 0x80004002
