Solution for cups-browsed destination problem
    [SOLVED] Solution for cups-browsed destination problem
    This is in fact a solution I have found for "no suitable destination host found by cups-browsed" here, which I found here. For some reason, I am not allowed to post a solution to the original post, even tho it does not seem to be marked as solved.
    The main thing is simply to purge cups-browsed:
    sudo apt-get purge --autoremove cups-browsed
    On one system, I did this, then undefined and redefined my printers by hand. On the other, just the purge was adequate.
    Hope this helps.
    Kubuntu Groovy Gorilla was released on October 22nd, 2020 with 9 months support. As of July 22nd, 2021, 20.10 reached end of life. As such, that forum was CLOSED.
