Odd kernel behavior 5.8.48 won't boot at all and 5.4.0-70 has dependencies in 5.8.38
    Two odd items: First off a month ago or so I manually installed 5.8.0-36 to move beyond the 5.4 series. I had left the last 5.4 kernel 5.4.0-69, on the system as a backup. A couple weeks later, an upgrade came the normal way for 5.8.0-38.
    I hadn't seen any update since them so I checked and sure enough -40 to -48 were available but not offered as install candidates via apt. However, I was offered an update to 5.4.0-69 to -70 (which was new - I check updates daily). I decided to install 5.8.0-48 and totally remove the 5.4 series.
    The install of 5.8.0-48 was no problem but trying to remove 5.4.0-60 was a mess. at least a dozen cross-depends with the 5.8 series like cloud-tools, modules-extra and more. This make no sense to me as they are different kernels and shouldn't be blended like that AFAIK. Especially when the conflicts were labeled 5.4.0-. Basically it wouldn't let me remove linux-image-5.4.0-69-generic without installing linux-image-5.4.0-69-unsigned in it's place.
    Not to be dictated to, I did it anyway and uninstalled everything relating to the 5.4 series.
    Then I installed 5.8.0-48 and rebooted - which failed. No problem, rebooted into 5.8.0-38 and restored my morning snapshot (took all of 15 seconds - BTRFS rocks and EXT4 sucks) and rebooted. This time I just installed the 5.8.0-48 kernel and rebooted - still failed. So apparently 5.8.0-48 is broken with regards to Neon.
    I haven't gone back and tried again to remove 5.4.0-70 now (I let it upgrade) but it sure seems odd that 54. and 5.8 are that closely tired. Seems wrong actually.
    [FONT=monospace][COLOR=#54FF54][B]stuart@office[/B][/COLOR][COLOR=#000000]:[/COLOR][COLOR=#54FFFF][B]~[/B][/COLOR][COLOR=#000000]$ remove --purge linux-image-5.4.0-70-generic[/COLOR]
    Reading package lists... Done
    Building dependency tree
    Starting pkgProblemResolver with broken count: 2
    Starting 2 pkgProblemResolver with broken count: 2
    Investigating (0) linux-modules-extra-5.4.0-70-generic:amd64 < 5.4.0-70.78 @ii mK Ib >
    Broken linux-modules-extra-5.4.0-70-generic:amd64 Depends on linux-image-5.4.0-70-generic:amd64 < 5.4.0-70.78 @ii pmP >
      Considering linux-image-5.4.0-70-generic:amd64 10002 as a solution to linux-modules-extra-5.4.0-70-generic:amd64 1
    Broken linux-modules-extra-5.4.0-70-generic:amd64 Depends on linux-image-unsigned-5.4.0-70-generic:amd64 < none | 5.4.0-70.78 @un uH >
      Considering linux-image-unsigned-5.4.0-70-generic:amd64 1 as a solution to linux-modules-extra-5.4.0-70-generic:amd64 1
      Try Installing linux-image-unsigned-5.4.0-70-generic:amd64 < none | 5.4.0-70.78 @un uH > before changing linux-modules-extra-5.4.0-70-generic:amd64
      Or group remove for linux-modules-extra-5.4.0-70-generic:amd64
    Investigating (0) linux-image-generic:amd64 < 5.4.0.70.73 @ii mK Ib >
    Broken linux-image-generic:amd64 Depends on linux-image-5.4.0-70-generic:amd64 < 5.4.0-70.78 @ii pmP >
      Considering linux-image-5.4.0-70-generic:amd64 10002 as a solution to linux-image-generic:amd64 0
      Removing linux-image-generic:amd64 rather than change linux-image-5.4.0-70-generic:amd64
    Done
      amd64-microcode intel-microcode iucode-tool linux-modules-extra-5.4.0-67-generic thermald
    Use 'sudo apt autoremove' to remove them.
    The following additional packages will be installed:
    Suggested packages:
      fdutils linux-doc | linux-source-5.4.0 linux-tools
      linux-image-5.4.0-70-generic* linux-image-generic* linux-modules-extra-5.4.0-70-generic*
    0 upgraded, 1 newly installed, 3 to remove and 0 not upgraded.
    Need to get 9,004 kB of archives.
    After this operation, 202 MB disk space will be freed.
    Do you want to continue? [Y/n] n
    Abort.
    [/FONT]
    How specifically did you install the 5.8? Using the linux-image-generic-hwe-20.04 meta-package?
    I am still confused a little, but that is not unusual for me today (both a and a )
    Here is my output, showing the expected removals of the meta-packages involved with the 5.4.0-70
    $ sudo apt purge linux-image-5.4.0-70-generic
    [sudo] password for claydoh:
    Considering linux-image-5.4.0-70-generic:amd64 10002 as a solution to linux-modules-extra-5.4.0-70-generic:amd64 2
    Broken linux-modules-extra-5.4.0-70-generic:amd64 Depends on linux-image-unsigned-5.4.0-70-generic:amd64 < none | 5.4.0-70.78 @un uH>
    Considering linux-image-unsigned-5.4.0-70-generic:amd64 1 as a solution to linux-modules-extra-5.4.0-70-generic:amd64 2
    Considering linux-image-5.4.0-70-generic:amd64 10002 as a solution to linux-image-generic:amd64 1
    Investigating (0) linux-generic:amd64 < 5.4.0.70.73 @ii mK Ib >
    Broken linux-generic:amd64 Depends on linux-image-generic:amd64 < 5.4.0.70.73 @ii mR > (= 5.4.0.70.73)
    Considering linux-image-generic:amd64 1 as a solution to linux-generic:amd64 0
    Removing linux-generic:amd64 rather than change linux-image-generic:amd64
    Done
    Suggested packages:
    linux-generic* linux-image-5.4.0-70-generic* linux-image-generic* linux-modules-extra-5.4.0-70-generic*
    The following NEW packages will be installed
    0 to upgrade, 1 to newly install, 4 to remove and 0 not to upgrade.
    Abort.
    I don't have anything related to 5.4.0-60 on my system., though I do notice that since installing the HWE metapackage, autotremove stopped removing older 5.4 kernels, so I had a few: -56, 62, 64, 65, 66, and 70, plus the related modules, modules-extras, etc.
    I have had no issue booting my PC with the current 5.8 kernel, and autoremove is keeping 6?? kernels there.
    I do wish that Neon would move to the official HWE track like I think they did with 18.04, or at least move the iso to a 20.04.2 base, and thus get off the 5.4 track altogether. I am ready for a clean install here on my PC. or maybe Ill look at 20.04.2's apt and autoremove configs, look for differences and apply them to the clean Neon.
      No, I didn't install the meta package so I tried that. It produced this error
      [FONT=monospace][COLOR=#000000]depmod: WARNING: could not open modules.order at /var/tmp/mkinitramfs_i5dObL/lib/modules/5.8.0-48-generic: No such file or directory[/COLOR]
      depmod: WARNING: could not open modules.builtin at /var/tmp/mkinitramfs_i5dObL/lib/modules/5.8.0-48-generic: No such file or directory
      [/FONT]
      which might be why I couldn't boot it. Still working on it.
        OK, weird I installed a couple more 5.8 meta packages, then updated initramfs and got this:
        [FONT=monospace][COLOR=#000000]depmod: WARNING: could not open modules.order at /var/tmp/mkinitramfs_VoofJK/lib/modules/5.8.0-48-generic: No such file or directory[/COLOR]
        depmod: WARNING: could not open modules.builtin at /var/tmp/mkinitramfs_VoofJK/lib/modules/5.8.0-48-generic: No such file or directory
        [/FONT]
        Then again and got:
        [FONT=monospace][COLOR=#000000]depmod: WARNING: could not open modules.order at /var/tmp/mkinitramfs_OYwa0D/lib/modules/5.8.0-48-generic: No such file or directory[/COLOR]
        depmod: WARNING: could not open modules.builtin at /var/tmp/mkinitramfs_OYwa0D/lib/modules/5.8.0-48-generic: No such file or directory
        [/FONT]
        The letters in the middle after "mkinitramfs_"appear to be random.
          Tried a couple things and discovered this:
          [FONT=monospace][COLOR=#54FF54][B]stuart@office[/B][/COLOR][COLOR=#000000]:[/COLOR][COLOR=#54FFFF][B]~[/B][/COLOR][COLOR=#000000]$ ll /lib/modules/5.8.0-38-generic/[/COLOR]
          total 5992
          drwxr-xr-x 1 root root     472 Mar 27 09:57 [COLOR=#54FFFF][B].[/B][/COLOR][COLOR=#000000]/[/COLOR]
          drwxr-xr-x 1 root root     160 Mar 27 09:37 [COLOR=#54FFFF][B]..[/B][/COLOR][COLOR=#000000]/[/COLOR]
          lrwxrwxrwx 1 root root      39 Jan 12 10:15 [COLOR=#FFFF54][B]build[/B][/COLOR][COLOR=#000000] -> [/COLOR][COLOR=#54FFFF][B]/usr/src/linux-headers-5.8.0-38-generic[/B][/COLOR][COLOR=#000000]/[/COLOR]
          drwxr-xr-x 1 root root       0 Jan 12 10:15 [COLOR=#54FFFF][B]initrd[/B][/COLOR][COLOR=#000000]/[/COLOR]
          drwxr-xr-x 1 root root     118 Jan 14 15:38 [COLOR=#54FFFF][B]kernel[/B][/COLOR][COLOR=#000000]/[/COLOR]
          -rw-r--r-- 1 root root 1423207 Mar 27 09:57 modules.alias
          -rw-r--r-- 1 root root 1402313 Mar 27 09:57 modules.alias.bin
          -rw-r--r-- 1 root root    9975 Jan 12 10:15 modules.builtin
          -rw-r--r-- 1 root root   25773 Mar 27 09:57 modules.builtin.alias.bin
          -rw-r--r-- 1 root root   12521 Mar 27 09:57 modules.builtin.bin
          -rw-r--r-- 1 root root   77263 Jan 12 10:15 modules.builtin.modinfo
          -rw-r--r-- 1 root root  649022 Mar 27 09:57 modules.dep
          -rw-r--r-- 1 root root  900049 Mar 27 09:57 modules.dep.bin
          -rw-r--r-- 1 root root     330 Mar 27 09:57 modules.devname
          -rw-r--r-- 1 root root  229525 Jan 12 10:15 modules.order
          -rw-r--r-- 1 root root     885 Mar 27 09:57 modules.softdep
          -rw-r--r-- 1 root root  616750 Mar 27 09:57 modules.symbols
          -rw-r--r-- 1 root root  752670 Mar 27 09:57 modules.symbols.bin
          drwxr-xr-x 1 root root      74 Jan 14 15:38 [COLOR=#54FFFF][B]vdso[/B][/COLOR][COLOR=#000000]/[/COLOR]
          [/FONT]
          vs this
          [FONT=monospace][COLOR=#54FF54][B]stuart@office[/B][/COLOR][COLOR=#000000]:[/COLOR][COLOR=#54FFFF][B]~[/B][/COLOR][COLOR=#000000]$ ll /lib/modules/5.8.0-48-generic/[/COLOR]
          total 4296
          drwxr-xr-x 1 root root     350 Mar 27 09:40 [COLOR=#54FFFF][B].[/B][/COLOR][COLOR=#000000]/[/COLOR]
          lrwxrwxrwx 1 root root      39 Mar 20 09:05 [COLOR=#FFFF54][B]build[/B][/COLOR][COLOR=#000000] -> [/COLOR][COLOR=#54FFFF][B]/usr/src/linux-headers-5.8.0-48-generic[/B][/COLOR][COLOR=#000000]/[/COLOR]
          drwxr-xr-x 1 root root     112 Mar 27 09:37 [COLOR=#54FFFF][B]kernel[/B][/COLOR][COLOR=#000000]/[/COLOR]
          -rw-r--r-- 1 root root 1276451 Mar 27 09:38 modules.alias
          -rw-r--r-- 1 root root 1252468 Mar 27 09:38 modules.alias.bin
          -rw-r--r-- 1 root root       0 Mar 27 09:38 modules.builtin.alias.bin
          -rw-r--r-- 1 root root       0 Mar 27 09:38 modules.builtin.bin
          -rw-r--r-- 1 root root  431963 Mar 27 09:38 modules.dep
          -rw-r--r-- 1 root root  642861 Mar 27 09:38 modules.dep.bin
          -rw-r--r-- 1 root root     114 Mar 27 09:38 modules.devname
          -rw-r--r-- 1 root root     426 Mar 27 09:38 modules.softdep
          -rw-r--r-- 1 root root  344251 Mar 27 09:38 modules.symbols
          -rw-r--r-- 1 root root  429916 Mar 27 09:38 modules.symbols.bin
          [/FONT]
          There's a lot missing from the 48 kernel modules
            I dunno.
            Though at some point since updating to the latest 5.8 (and probably the latest 5.4) on my PC, I have lost bluetooth altogether, no matter which kernel I use. I have a realtek one using the rtl8821ce, which needs a dkms drver package, or a dkms build from git. Flaky at times but usually working and fixable.
              Odd. Mine looks the same as my other 5.8 kernels:
              claydoh@hp:~$ ls -la /lib/modules/5.8.0-48-generic/
              total 6012
              drwxr-xr-x  6 root root    4096 Mar 27 09:36 .
              drwxr-xr-x 11 root root    4096 Mar 26 17:47 ..
              lrwxrwxrwx  1 root root      39 Mar 20 09:05 build -> /usr/src/linux-headers-5.8.0-48-generic
              drwxr-xr-x  2 root root    4096 Mar 20 09:05 initrd
              drwxr-xr-x 15 root root    4096 Mar 24 07:41 kernel
              -rw-r--r--  1 root root 1425343 Mar 27 09:36 modules.alias
              -rw-r--r--  1 root root 1404478 Mar 27 09:36 modules.alias.bin
              -rw-r--r--  1 root root    9975 Mar 20 09:05 modules.builtin
              -rw-r--r--  1 root root   25773 Mar 27 09:36 modules.builtin.alias.bin
              -rw-r--r--  1 root root   12521 Mar 27 09:36 modules.builtin.bin
              -rw-r--r--  1 root root   77339 Mar 20 09:05 modules.builtin.modinfo
              -rw-r--r--  1 root root  649076 Mar 27 09:36 modules.dep
              -rw-r--r--  1 root root  900127 Mar 27 09:36 modules.dep.bin
              -rw-r--r--  1 root root     330 Mar 27 09:36 modules.devname
              -rw-r--r--  1 root root  229525 Mar 20 09:05 modules.order
              -rw-r--r--  1 root root     885 Mar 27 09:36 modules.softdep
              -rw-r--r--  1 root root  616586 Mar 27 09:36 modules.symbols
              -rw-r--r--  1 root root  752628 Mar 27 09:36 modules.symbols.bin
              drwxr-xr-x  2 root root    4096 Mar 27 09:36 updates
              drwxr-xr-x  3 root root    4096 Mar 24 07:41 vdso
              and my oldest:
              claydoh@hp:~$ ls -la /lib/modules/5.8.0-40-generic/
              total 6008
              drwxr-xr-x  5 root root    4096 Mar  1 16:53 .
              lrwxrwxrwx  1 root root      39 Jan 15 06:09 build -> /usr/src/linux-headers-5.8.0-40-generic
              drwxr-xr-x  2 root root    4096 Jan 15 06:09 initrd
              drwxr-xr-x 15 root root    4096 Jan 20 13:54 kernel
              -rw-r--r--  1 root root 1423207 Mar  1 16:53 modules.alias
              -rw-r--r--  1 root root 1402313 Mar  1 16:53 modules.alias.bin
              -rw-r--r--  1 root root    9975 Jan 15 06:09 modules.builtin
              -rw-r--r--  1 root root   25773 Mar  1 16:53 modules.builtin.alias.bin
              -rw-r--r--  1 root root   12521 Mar  1 16:53 modules.builtin.bin
              -rw-r--r--  1 root root   77263 Jan 15 06:09 modules.builtin.modinfo
              -rw-r--r--  1 root root  649022 Mar  1 16:53 modules.dep
              -rw-r--r--  1 root root  900049 Mar  1 16:53 modules.dep.bin
              -rw-r--r--  1 root root     330 Mar  1 16:53 modules.devname
              -rw-r--r--  1 root root  229525 Jan 15 06:09 modules.order
              -rw-r--r--  1 root root     885 Mar  1 16:53 modules.softdep
              -rw-r--r--  1 root root  616750 Mar  1 16:53 modules.symbols
              -rw-r--r--  1 root root  752670 Mar  1 16:53 modules.symbols.bin
              drwxr-xr-x  3 root root    4096 Jan 20 13:54 vdso
                OK, re-installing ALL the 5.8.0-48 packages added the missing modules and initramfs built without error.
                  Boots fine to 48 now but still weird circular depends:
                  [FONT=monospace][COLOR=#54FF54][B]stuart@office[/B][/COLOR][COLOR=#000000]:[/COLOR][COLOR=#54FFFF][B]~[/B][/COLOR][COLOR=#000000]$ remove --purge linux-cloud-tools-common[/COLOR]
                  Starting pkgProblemResolver with broken count: 4
                  Starting 2 pkgProblemResolver with broken count: 4
                  Investigating (0) linux-hwe-5.8-cloud-tools-5.8.0-45:amd64 < 5.8.0-45.51~20.04.1 @ii mK Ib >
                  Broken linux-hwe-5.8-cloud-tools-5.8.0-45:amd64 Depends on linux-cloud-tools-common:amd64 < 5.4.0-70.78 @ii pmP >
                    Considering linux-cloud-tools-common:amd64 10004 as a solution to linux-hwe-5.8-cloud-tools-5.8.0-45:amd64 1
                    Removing linux-hwe-5.8-cloud-tools-5.8.0-45:amd64 rather than change linux-cloud-tools-common:amd64
                  Investigating (0) linux-hwe-5.8-cloud-tools-5.8.0-48:amd64 < 5.8.0-48.54~20.04.1 @ii mK Ib >
                  Broken linux-hwe-5.8-cloud-tools-5.8.0-48:amd64 Depends on linux-cloud-tools-common:amd64 < 5.4.0-70.78 @ii pmP >
                    Considering linux-cloud-tools-common:amd64 10004 as a solution to linux-hwe-5.8-cloud-tools-5.8.0-48:amd64 1
                    Removing linux-hwe-5.8-cloud-tools-5.8.0-48:amd64 rather than change linux-cloud-tools-common:amd64
                  Investigating (0) linux-hwe-5.8-cloud-tools-5.8.0-36:amd64 < 5.8.0-36.40~20.04.1 @ii mK Ib >
                  Broken linux-hwe-5.8-cloud-tools-5.8.0-36:amd64 Depends on linux-cloud-tools-common:amd64 < 5.4.0-70.78 @ii pmP >
                    Considering linux-cloud-tools-common:amd64 10004 as a solution to linux-hwe-5.8-cloud-tools-5.8.0-36:amd64 1
                    Removing linux-hwe-5.8-cloud-tools-5.8.0-36:amd64 rather than change linux-cloud-tools-common:amd64
                  Investigating (0) linux-hwe-5.8-cloud-tools-5.8.0-38:amd64 < 5.8.0-38.43~20.04.1 @ii mK Ib >
                  Broken linux-hwe-5.8-cloud-tools-5.8.0-38:amd64 Depends on linux-cloud-tools-common:amd64 < 5.4.0-70.78 @ii pmP >
                    Considering linux-cloud-tools-common:amd64 10004 as a solution to linux-hwe-5.8-cloud-tools-5.8.0-38:amd64 1
                    Removing linux-hwe-5.8-cloud-tools-5.8.0-38:amd64 rather than change linux-cloud-tools-common:amd64
                  Investigating (0) linux-cloud-tools-5.8.0-45-generic:amd64 < 5.8.0-45.51~20.04.1 @ii mK Ib >
                  Broken linux-cloud-tools-5.8.0-45-generic:amd64 Depends on linux-hwe-5.8-cloud-tools-5.8.0-45:amd64 < 5.8.0-45.51~20.04.1 @ii mR >
                    Considering linux-hwe-5.8-cloud-tools-5.8.0-45:amd64 1 as a solution to linux-cloud-tools-5.8.0-45-generic:amd64 0
                    Removing linux-cloud-tools-5.8.0-45-generic:amd64 rather than change linux-hwe-5.8-cloud-tools-5.8.0-45:amd64
                  Investigating (0) linux-cloud-tools-5.8.0-48-generic:amd64 < 5.8.0-48.54~20.04.1 @ii mK Ib >
                  Broken linux-cloud-tools-5.8.0-48-generic:amd64 Depends on linux-hwe-5.8-cloud-tools-5.8.0-48:amd64 < 5.8.0-48.54~20.04.1 @ii mR >
                    Considering linux-hwe-5.8-cloud-tools-5.8.0-48:amd64 1 as a solution to linux-cloud-tools-5.8.0-48-generic:amd64 0
                    Removing linux-cloud-tools-5.8.0-48-generic:amd64 rather than change linux-hwe-5.8-cloud-tools-5.8.0-48:amd64
                  Investigating (0) linux-cloud-tools-5.8.0-36-generic:amd64 < 5.8.0-36.40~20.04.1 @ii mK Ib >
                  Broken linux-cloud-tools-5.8.0-36-generic:amd64 Depends on linux-hwe-5.8-cloud-tools-5.8.0-36:amd64 < 5.8.0-36.40~20.04.1 @ii mR >
                    Considering linux-hwe-5.8-cloud-tools-5.8.0-36:amd64 1 as a solution to linux-cloud-tools-5.8.0-36-generic:amd64 0
                    Removing linux-cloud-tools-5.8.0-36-generic:amd64 rather than change linux-hwe-5.8-cloud-tools-5.8.0-36:amd64
                  Investigating (0) linux-cloud-tools-5.8.0-38-generic:amd64 < 5.8.0-38.43~20.04.1 @ii mK Ib >
                  Broken linux-cloud-tools-5.8.0-38-generic:amd64 Depends on linux-hwe-5.8-cloud-tools-5.8.0-38:amd64 < 5.8.0-38.43~20.04.1 @ii mR >
                    Considering linux-hwe-5.8-cloud-tools-5.8.0-38:amd64 1 as a solution to linux-cloud-tools-5.8.0-38-generic:amd64 0
                    Removing linux-cloud-tools-5.8.0-38-generic:amd64 rather than change linux-hwe-5.8-cloud-tools-5.8.0-38:amd64
                  Done
                    linux-cloud-tools-5.8.0-36-generic* linux-cloud-tools-5.8.0-38-generic* linux-cloud-tools-5.8.0-45-generic* linux-cloud-tools-5.8.0-48-generic*
                    linux-cloud-tools-common* linux-hwe-5.8-cloud-tools-5.8.0-36* linux-hwe-5.8-cloud-tools-5.8.0-38* linux-hwe-5.8-cloud-tools-5.8.0-45*
                    linux-hwe-5.8-cloud-tools-5.8.0-48*
                  0 upgraded, 0 newly installed, 9 to remove and 0 not upgraded.
                  After this operation, 2,952 kB disk space will be freed.
                  [/FONT]
