Installing KDEneon 20.04 in legacy mode - no UEFI
    I was unable to install KDEneon 20.04 on my system because there was no apparent way to do so without EFI, so I settled for a do-release-upgrade instead.
    I did figure out a pretty easy way to get it done though:
    Download and install Ubuntu Server - Legacy version
    Run:
    sudo apt update
    sudo apt full-upgrade
    Create the KDEneon sources list in in /etc/apt/sources.list.d/neon.list
    sudo echo "deb http://archive.neon.kde.org/user focal main" > /etc/apt/sources.list.d/neon.list
    Update your sources again:
    sudo apt update
    You should then get an error regarding a missing PUBKEY, then run this
    (verify the key is the same as the error messsage):
    sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys E6D4736255751E5D
    Then run:
    sudo apt update
    sudo apt install neon-desktop
    and 1500+ packages will download and install.
    When that's done, reboot.
    Typical oshunluvr!
    Neat!
