Updated neon 20.04 (upgraded from 18.04 because the new installer does not allow legacy installation)
Either the last update (this morning, about a weeks worth up updates) or removing kscreen and using an xrandr script to set my monitors correctly (because kscreen will not keep it's settings) has resulted in no longer being able to use my monitor speakers.
It appears pulseaudio is no longer correctly identifying my audio outputs correctly.
Here's the out put of aplay -l:
Here's the connected monitors:
Here's what system settings shows:
You can see two devices that are NOT connected show connected and the two ACTUALLY connected show unconnected.
And ideas where to start?
[FONT=monospace][COLOR=#54FF54][B]stuart@office[/B][/COLOR][COLOR=#000000]:[/COLOR][COLOR=#54FFFF][B]~[/B][/COLOR][COLOR=#000000]$ aplay -l[/COLOR] **** List of PLAYBACK Hardware Devices **** card 0: PCH [HDA Intel PCH], device 0: ALC1220 Analog [ALC1220 Analog] Subdevices: 1/1 Subdevice #0: subdevice #0 card 0: PCH [HDA Intel PCH], device 1: ALC1220 Digital [ALC1220 Digital] Subdevices: 1/1 Subdevice #0: subdevice #0 card 1: HDMI [HDA ATI HDMI], device 3: HDMI 0 [HDMI 0] Subdevices: 1/1 Subdevice #0: subdevice #0 card 1: HDMI [HDA ATI HDMI], device 7: HDMI 1 [HDMI 1] Subdevices: 1/1 Subdevice #0: subdevice #0 card 1: HDMI [HDA ATI HDMI], device 8: HDMI 2 [HDMI 2] Subdevices: 1/1 Subdevice #0: subdevice #0 card 1: HDMI [HDA ATI HDMI], device 9: HDMI 3 [HDMI 3] Subdevices: 1/1 Subdevice #0: subdevice #0 card 1: HDMI [HDA ATI HDMI], device 10: HDMI 4 [HDMI 4] Subdevices: 1/1 Subdevice #0: subdevice #0 card 1: HDMI [HDA ATI HDMI], device 11: HDMI 5 [HDMI 5] Subdevices: 1/1 Subdevice #0: subdevice #0 [/FONT]
[FONT=monospace][COLOR=#54FF54][B]stuart@office[/B][/COLOR][COLOR=#000000]:[/COLOR][COLOR=#54FFFF][B]~[/B][/COLOR][COLOR=#000000]$ xrandr[/COLOR] Screen 0: minimum 320 x 200, current 4920 x 1920, maximum 16384 x 16384 DisplayPort-0 disconnected (normal left inverted right x axis y axis) DisplayPort-1 disconnected (normal left inverted right x axis y axis) DisplayPort-2 disconnected (normal left inverted right x axis y axis) HDMI-A-0 connected 1080x1920+3840+0 right (normal left inverted right x axis y axis) 527mm x 296mm DVI-D-0 disconnected (normal left inverted right x axis y axis) DisplayPort-3 connected primary 3840x1600+0+0 (normal left inverted right x axis y axis) 880mm x 367mm DisplayPort-4 disconnected (normal left inverted right x axis y axis) [/FONT]
