Well, I just did updates today and no login screen. Didn't see this in time. I can get to TTY screen. How to fix? Or, just wait for next round of updates? This PC is more of a test system than my day to day.
Well, my KDE neon, which was dist-upgraded this morning, boots up just fine (just did a minute ago). System Information reports:
KDE neon 5.19 User Edition
KDE Plasma Version: 5.19.5
KDE Frameworks Version: 5.73.0
Qt Version: 5.14.2
Kernel Version: 5.4.0-45-generic
OS Type: 64-bit
So is Qt 5.15 not in the User Edition? Is this specifically an issue with the Developer Edition?
Qt Version: 5.14.2
OS Type: 64-bit
No, this was only on some User installs, the 5.15 was not supposed to be there. For some it seems the neon.list file for those of us with the problem had the repo set to the 'release' pocket somehow as opposed to the normal 'user'.
For whatever reason, the 'release' pocket is for testing, not sure if it is for build testing or for general use testing.
I'm supposed to be on User. Really odd. If they removed the packages then not sure why mine is borked. I'll check the list file and see what mine has there.
So was I. I don't think the update was pulled, it seems we may have had the wrong repo set via installer or upgrade
I never looked at my repos before I recovered, and my backup was actually from my PC, which did not have the Qt package updates.
And that explains my case; I have 'user' in the repo list entry.
May be how I originally installed. It was during testing phase and those must be set wrong now. I'm getting resolve errors on most of my package list on apt update.
I'll pull a new ISO down and reinstall. I think it would be best for me at the moment. Just need to figure how to save my files as this had no separate /home location.
They have released the new Ubuntu LTS base have they not?
If you installed neon 20.04 from the pre-release ISOs during the testing phase, your neon.list file was set to the "release" repo. I noticed one machine was getting updates before all the others, and that was the release machine. I changed the repo to user a few days ago.
If you waited for the official upgrade to 20.04, you should be fine.
So, all seems fine now. Tried to do an install over what I had without formatting. Never tried that before and since test system thought, eh, why not! That didn't work so clean install.
It does definitely boots different so that testing image, even with updates, must have had issues I didn't know about. It's a happy test system now!
