Hi all,
I hope its okay to ask a Neon question here?
Ran the standard upgrade, from 18.04, after initial required updates/upgrades.
It ran okay to a point then I got;
Then
Then
I ran the upgrade again, I get ...
Attempting upgrades on the terminal gives
sudo pkcon update:
[COLOR=var(--newRedditTheme-monospaceColor)]Fatal error: WARNING: You are trying to remove the following essential packages: libapt-pkg5.0 (due to apt)[/COLOR]
Can anyone advise please?
Thanks.
Then
Then
sudo pkcon update:
Thanks.
