Small but annoying problem:
If I want to connect a bluetooth speaker, it won't play any sound unless I disconnect the headphones.
Which are always plugged in, at the back of the box, and you sort of have to use diving gear to get there.
I can't find any settings to tell the PC to play both at the same time.
If I plug a line-connected speaker to a physical connector, they both work...
