That latest upgrade has left me with some problems. At least, I suppose it was that since all worked well yesterday evening and I did the update this morning. I was in 4.15.0-65-generic both before and after the update.
Now my bluetooth-connected speakers don't work any more. When I try to enable a device, the enable fails. Now it has even deleted the device and cannot find it.
	What function is not implemented?
	$ sudo service bluetooth status -l
[sudo] password for jon:
● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2019-10-19 07:55:41 CEST; 11h ago
  Docs: man:bluetoothd(8)
Main PID: 975 (bluetoothd)
Status: "Running"
 Tasks: 1 (limit: 4915)
CGroup: /system.slice/bluetooth.service
        └─975 /usr/lib/bluetooth/bluetoothd
oct. 19 07:55:54 jon-desktop bluetoothd[975]: Endpoint registered: sender=:1.66 path=/MediaEndpoint/A2DPSink
oct. 19 18:08:04 jon-desktop bluetoothd[975]: connect error: Function not implemented (38)
oct. 19 18:08:40 jon-desktop bluetoothd[975]: connect error: Function not implemented (38)
oct. 19 18:09:16 jon-desktop bluetoothd[975]: connect error: Function not implemented (38)
oct. 19 18:09:52 jon-desktop bluetoothd[975]: connect error: Function not implemented (38)
oct. 19 18:09:52 jon-desktop bluetoothd[975]: 04:FE:A1:43:3C:23: error updating services: Function not implemented (38)
oct. 19 18:10:34 jon-desktop bluetoothd[975]: connect error: Connection timed out (110)
oct. 19 18:11:10 jon-desktop bluetoothd[975]: connect error: Function not implemented (38)
oct. 19 18:11:10 jon-desktop bluetoothd[975]: 04:FE:A1:43:3C:23: error updating services: Function not implemented (38)
oct.
19 18:12:15 jon-desktop bluetoothd[975]: connect error: Software caused connection abort (103)
