Hi
This is not an emergency I'm just looking for comments.
It so happens that I had to fill out a .pdf which had "fillable forms" that is PDF 1.7. This is a "linearized" also, apparently, "compressed" form. I was, after some time able to "fill out the form" in the online part of a website. However, before i got "there" I downloaded the form, and did not know how I could "resubmit" it except to take it to the workplace and hand in a paper form.
So that sent me on a "quest" and I discovered the whole thing about the 1.7 pdf form etc.
So to cut to the chase.
When I open it in Okular, Okular says that it has "forms", which, when clicked will normally show the "boxes" that are fillable.
This works with forms from the college etc. and I normally use Okular to do this and it has always worked well.
But, not with this form.
So, again to cut to the chase, I downloaded every single version of anything that would "deal" with a .pdf and they would all, in one way or another allow me to PLACE TEXT into a PLACE on the .pdf but, again, did not actually SHOW THE FILLABLE BOXES...
So, the question is this.
Does anyone happen to know if there is a "situation" with the .pdf 1.7 which is unique to not having the commercial adobe software to fill out the form?
AS AN ASIDE...this may actually be a situation with using NEON in that NEON does not provide the ability to interact with anything other than a "normal" .pdf ...
BTW I use Neon for my work machine because I assumed, and we know what that means !
, that it would have the latest and greatest but it might be that plain Kubuntu might be able to handle this.
Again, just asking for comments.
woodthanksaheadoftimesmoke
