I am getting pretty annoyed with this system. Probably, the most salient information you will want to know is that I did an in-place upgrade from Neon 16.04 to 18.04. At the time I was pleasantly surprised that most things upgraded without drama but, over time, I have seen some things which have grown from annoyances to aggravations. This brings this introduction to the main issue: the upgrade/updating process.
I realize that Discover is an on-going annoyance that, for the most part, has worked OK for me. But now my system tray gadget says 10 packages to update. I select view updates which brings up Discover. Discover shows 6 updates - but the top line which normally displays 'Check for updates' and 'Update all' are greyed-out.
So, going to the Terminal I do the current recommended 'pkcon refresh' and 'pkcon update' which gets me nowhere. Then, after searching this forum I found a recommendation to do 'sudo apt-get dist-upgrade' which does update some of the files. Then, after rebooting the system tray gadget reports 6 packages and Discovery reports 3.
I have limped along, for weeks now, ignoring the annoyances. Can anyone help me?
-=Ken=-
-=Ken=-
