Has anyone tried to add Neon repositories to Kubuntu 18.04 in order to get a hybrid Neon based on Kubuntu rather than Ubuntu with the new 18.04 Neon? I did this with Kubuntu 16.04 and got good results. In the end, I had an OS which had the very latest Neon updates (dev edition) as well as the latest Linux kernel updates, yet still ran all the Kubuntu stuff, even Wine-based programs. The only reason I changed to Kubuntu 18.04 was to try the btrfs file system, which I did not have. Kubuntu 18.04 is running fine for me, so I have been reluctant to try this possibly risky move to a new hybrid Neon. Has anyone else tried? Results?
Hybrid Neon anyone?
As you may remember I also was running a Kubuntu-16.04 with the Neon-/dev/stable repo added , I still am , but I did the 18.04 upgrade on it
Code:Operating System: KDE neon Developer Edition KDE Plasma Version: 5.14.3 Qt Version: 5.11.2 KDE Frameworks Version: 5.53.0 Kernel Version: 4.15.0-38-generic OS Type: 64-bit Processors: 8 × Intel® Core™ i7-4910MQ CPU @ 2.90GHz Memory: 15.6 GiB of RAM
I do not use "wine" so I cant comment on that !
I just put it in /etc/apt/sources.list .
it being ,Code:#disabled on upgrade to bionic deb http://archive.neon.kde.org/stable/ bionic main # deb-src http://archive.neon.kde.org/stable/ xenial main
the location of mine was the cause of some ,,,,,,,slight trouble during my 16.04 to 18.04 upgrade ,,,,,,it got commented out during the upgrade .
had to do some serious putzing around to get the GUI desktop back ,,,,LOL
Launch Kate and create a new file. Paste this line into that new file:
Save the file as neon.list in /etc/apt/sources.list.d
You will be asked for your password, as you are saving the file to a location owned by root.Windows no longer obstructs my view.
Most likely would be file overwrite and/or package conflicts on upgrade. Some maybe easily solvable, some maybe difficult. Get your apt and dpkg man pages ready...
Neon and Kubuntu share a historical packaging base, and over time many of the same changes have been made the same way (even at the same time by the same people), but packaging decisions such as moving files from one package to another, or replacing/renaming a package may have been made or merged from debian at different times. So for example the breaks/replaces against package <= xx version that help apt handle such situations without breakage will be different and incompatible between Neon archive and the ones already installed. i.e. the Neon ones are set to upgrade from previous Neon version safely, not the Kubuntu ones.
Some just have to have their Kubuneon or would it be Neobuntu?Windows no longer obstructs my view.
Originally posted by acheron View PostMost likely would be file overwrite and/or package conflicts on upgrade. Some maybe easily solvable, some maybe difficult. Get your apt and dpkg man pages ready...
@oldgeek is not trying to do a 16.04 to 18.04 upgrade , just add the neon repo to 18.04 so should be good , but since I have a Kubuntu-18.04 in a BTRFS file system , I will some time this weekend take a snapshot of it's current state (rather stock) and try it myself then just put back the stock Kubuntu and report the result .
well hears the report ,,,in short , it was as @acheron described ,,,,a mess
started off withCode:492 upgraded, 68 newly installed, 22 to remove and 0 not upgraded. Need to get 294 MB of archives. After this operation, 7,826 kB of additional disk space will be used. Do you want to continue? [Y/n]
that's when the fun started , dpkg errors trying to over write and cant ,lots of "sudo apt --fix-broken install" and "sudo apt-get update && sudo apt-get dist-upgrade" and "sudo dpkg -i --force-all /var/cache/apt/archives/package-name" .
until it finally settled down with apt-get dist-upgrade reporting nothing to do , then a "install neon-desktop" to finish it all off and it seems good BUT it was very problematic to say the least .
Code:Operating System: KDE neon Developer Edition KDE Plasma Version: 5.14.3 Qt Version: 5.11.2 KDE Frameworks Version: 5.53.0 Kernel Version: 4.18.0-11-generic OS Type: 64-bit Processors: 8 × Intel® Core™ i7-4910MQ CPU @ 2.90GHz Memory: 15.6 GiB of RAM
that is ,,,,I made the snapshot "@-snap2" and "@home-snap2" right before the adventure , I will now boot to a different system and rename @ to @old , @home to @home-old and then @-snap2 to @ and @home-snap2 to @home then reboot back to my Kubuntu-18.04 , if all is well then I will delete the @old and @home-old.
all for now
