Totally new install of Neon using btrfs, and thanks to Greygeek for the excellent instructions.
Appreciate KMM is Kubuntu based but it always ran without problem and is not available as an appimage.
KMM installs ok but seg faults on setting up the first account. I have run it from Konsole and used gdb to produce a report if of any use.
Anyone use KMM on the latest Neon? Aptitude shows 54 dependencies but installation pulls in over 100, so the problem might lay buried.
Edit - found a possible fault based on desktop theme so changed from Breeze to Oxygen but without success.
