Problem with phpmyadmin in 18.04
    [SOLVED] Problem with phpmyadmin in 18.04
    I can neither uninstall nor configure phpmyadmin.
    Installation of apache2 and php7.2 went smoothly. Installation of mysql has changed since16.04. Now you just install mysql-server and it installs the client automatically. But then you must run
    sudo mysql_secure_installation
    to configure it. This is new, at least to me.
    Then when installing phpmyadmin, it asks which server, apache2 or something else, to use. That is where I messed up because I could not figure out how to choose apache2. (Need to use the space key. Who would have thought of that?) Frankly, I'm not sure what I did, but the subsequent installation of phpmyadmin failed. I tried purging it and doing all sorts of stuff I found on the web, like use 'rm -rf' to delete stuff by hand. Now I have this:
    $ sudo apt install phpmyadmin php-mbstring php-gettext
    Reading package lists... Done
    Building dependency tree
    php-gettext is already the newest version (1.0.12-0.1).
    php-mbstring is already the newest version (1:7.2+60ubuntu1).
    phpmyadmin is already the newest version (4:4.6.6-5).
    Starting pkgProblemResolver with broken count: 0
    Starting 2 pkgProblemResolver with broken count: 0
    Done
    1 not fully installed or removed.
    After this operation, 0 B of additional disk space will be used.
    Do you want to continue? [Y/n]
    Setting up phpmyadmin (4:4.6.6-5) ...
    dbconfig-common: writing config to /etc/dbconfig-common/phpmyadmin.conf
    dbconfig-common: flushing administrative password
    dpkg: error processing package phpmyadmin (--configure):
    installed phpmyadmin package post-installation script subprocess returned error exit status 10
    phpmyadmin
    Suggestions on the internet say to fiddle around with stuff in /var/lib/dpkg/info/phpmyadmin.postinst, but that file is meaningless to me. Another suggestion gave this:
    $ sudo dpkg --configure -a
    phpmyadmin
    How can I get past this hurdle? I would think that a complete removal of phpmyadmin would do the trick, but the arcana of package handling are beyond my ken.
    https://www.kubuntuforums.net/showth...admin-in-18-04
    Double posting a problem won't get you twice the help!
      Ohmygosh! I don't know how that happened. A thousand excuses! I can't see how to delete this one, so I will mark it "solved".
      Thanks for pointing this out.
