Screen brightness and Plasma 6 with HDR not staying set. How to set default?
    I've been trying enabling HDR off and on for the last few months. Color washout was horrible for quite awhile, but now it seems fixed. I re-enabled HDR a couple weeks ago but have not been able to get the screen brightness to a comfortable level. It was super annoying to see the bright SDDM log in screen only to have my screens dim so much after log in that I had to turn off the room lights and squint a bit. I was just hanging on thinking there would be a fix, but nothing yet. Then, I discovered I was a dummy when I finally saw the screen brightness controls in the system tray added by a some update in the past. Hurray! I can see my screens in daylight again!
    However, it appears when my screens go into power saving mode due to non-use, they restore to - maybe random - low levels. I've only seen this once so far, but after setting both screens at 30% and returning awhile later, screen 1 restored at 1% and screen 2 to 3%.
    I can find no entry in Systems Settings to set a default brightness - only "Night Light" screen temps.
    Alternately, just having it restore to the previous setting would be even better.
    EDIT: Well, yesterdays update and a reboot and the brightness settings were retained. I don't know why, but at least it's fixed - for now.
    Issue came back. Maybe because of night time settings?
