Lack of default and simulated audio devices.
    Since the upgrade to 24.04, VLC has been barfing when launched. The error messages regard "Default" audio device missing. Well maybe that's because there doesn't seem to be a way to assign a default audio device. Also, in the past, we could create a "simulated" audio device that allowed one to combine multiple outputs. This worked well for me as I have two monitors with speakers, bluetooth headphones, and a Bose soundbar.
    I wonder if anyone else has this complaint or is it just me?
    Hi there oshunluvr
    I have been using VLC with 24.04 and no problem at all. About a virtual ( simulated ) audio i never used it before, so i cant help on it. I am on VLC Ubuntu 3.0.20-3 build6 version from discover.
      Maybe I wasn't clear: My VLC works fine unless you have it set to "Default" as the source. When I upgraded from KDEneon 22.04 to 24.04 is when the errors began appearing. I can select a specific audio output in VLC and the errors stop, but this is sub-optimal because that means I have to change the audio device twice when I want to use a different output than I currently have selected.
      Prior to the upgrade, I only had to select the audio device in the System Tray > Audio and VLC would play on whatever output I selected. This is no longer the case.
      To further illustrate my point that this is a bug, the System Tray > Audio widget allows you to check "Show virtual devices" for the output but there are none because System Settings > Sound no longer has the option to create a virtual output.
        I got it now.
        Try in konsole:
        pactl load-module module-combine-sink
        it works for me and i can use virtual devices. In this way i can create a virtual audio device that allowed one to combine multiple outputs.
          Sweet! Thanks. had to install pulseaudio also but after that I could enter the command you suggested and a "combined" audio device appeared. Now I need to see if I can assign it to VLC and if it will exist after a reboot.
            Unfortunately that did not work. I'm getting no sound at all.
              Maybe because you loaded pulseaudio server. It works for me like a charm but i dont use pulseaudio server. I use pipewire and i have pipewire-pulse instead pulseaudio server.
              Try to remove pulseaudio server and use pipewire and check if you installed pipewire-pulse.
              In time: this command does not survive a coldstart. I need to Know where to install the module to run.
                if the command does not require sudo, then put it in ~/.profile.
                Ok, I tried again and only installed pulseaudio-utils and then the command would run. It's currently working with Amarok. I'll try and see if I can configure VLC to work also.
                Would you mind checking your VLC and posting what audio source is selected? It's in Tool > Preferences > Audio > then Output module and Device. Thanks.
                  Don't discount that if VLC is from neon, you might look at a different source, just to check. Or vice versa. I don't know off the top of my head if Neon still builds VLC or not. Neon uses pipewire/wireplumber and 24.04 is still pulseaudio, so maybe that is a factor, maybe, if it is an Ubuntu package, looking for pulseaudio, maybe?? Pure speculation though. Pipewire-pulse is supposed to handle things that want pulseaudio, but you know.....
                  VLC for me has been on a downturn in the past year or so, for me. Inconsistent and fidgety. I've been using Haruna myself. I've not seen your issue using this, but I also haven't used VLC to see if it is the same for me. I routinely switch between 2 to 4 different output sources.
                  I'll take a peek and see how VLC is misbehaving.
                  • oshunluvr
                    oshunluvr commented
                    Editing a comment
                    Yeah, VLC has been a PITA in the recent past, but has been OK for a year or so until the upgrade to 24.04 base.
                  PipeWire audio output, but works fine with PulseAudio output and Alsa Audio Output too. Using PipeWire Audio Output and Pulse Audio Output there is no device to select. Only when i choose Alsa i can select a device that are a lot of choice ( I use two sound card and one of them is Creative Live Drive ) . I did a test only with this device : Default Alsa Output ( Currently PipeWire Media Server ) and...works fine.
                  I use Pipewire-alsa, Pipewire-Pulse, Pipewire-Jack, Pipewire-audio and VLC-plugin-Pipewire
                    I wonder if it is an artifact of the upgrade. I have no issues, but I have clean installs everywhere now. So, of course I have zero issues with audio switching in VLC (video playing on the other hand.......arghh... but better than I remember. It may be my video sources while sailing the high seas)
                    As for virtual devices, I know pipewire can do this, but of course KDE folks seem to let this stuff linger before they re-implement things in the UI.
                    I read that pavucontrol supports pipewire and may do what you are looking for.
                    qpwgraph might be useful, too. A bit much, maybe.
                      I never had issues with pulse audio pre 24.04 upgrade. There used to be the "Simultaneous" output option, which was brilliant and worked flawlessly for HDMI & Line out.
                      Now we have to use the "pactl load-module module-combine-sink" command, which is a PITA as one has to initiate it at every reboot (I suck at script writing). It would be nice to know why that functionality was removed.
