Very often I turn on my (desktop) PC and the Lenovo logo appears and the PC appears to boot but I don't
get a log-in screen. If I pull the HDMI cable and switch it to the built-in HDMI port it works. This is not
ideal because the built in GPU is no good for X-Plane!
If I hit F12 during boot I can go into BIOS settings and switch from IGD (integrated) to PEG (PCI GPU) and
reboot. Sometimes this works but mostly I have to do that three or four times before the setting sticks!
At first I thought it was the RTC battery but it's only the one setting being reset to default!
This never happened before I installed the latest Neon!
