Problems with skanlite, snap and d-bus
    [RESOLVED] Problems with skanlite, snap and d-bus
    I wanted to install skanlite on my computer, Looking how to do so, I fell on a method using snap. (I do not like snap.) From then on, only problems.
    $ sudo snap install skanlite
    2024-02-06T11:56:05+01:00 INFO cannot update "cups", will not have required content "foo": snap has no updates available
    skanlite 23.08.4 from KDE✓ installed​
    But then I could not start it from the application launcher. By hand,
    $ skanlite
    dbus[9809]: D-Bus library appears to be incorrectly set up: see the manual page for dbus-uuidgen to correct this issue. (Failed to open "/var/lib/dbus/machine-id": No such file or directory; Failed to open "/etc/machine-id": No such file or directory)
    D-Bus not built with -rdynamic so unable to print a backtrace
    Aborted​
    I then tried to install it directly with apt, which seemed to work. Did I now have two copies installed? Anyway, starting it by the command line gave the same d-bus error message, which means nothing to me. So I removed it with apt, which seemed to work. Same d-bus error I tried to remove it with snap and got the message "skanlite removed". I removed it again with apt, and now I get:
    $ skanlite
    bash: /snap/bin/skanlite: No such file or directory​
    And still
    $ dpkg -l skanlite
    Desired=Unknown/Install/Remove/Purge/Hold
    | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
    |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
    ||/ Name Version Architecture Description
    ii skanlite 23.08.4-0xneon+22.04+jammy+release+build27 amd64 image scanner based on the KSane backend
    I realize I have done too many things without proper correlation. But how do I fix this mess? Dpkg still thinks it is installed but the CL gives me a message from snap.
    Why in the world is this thing availbable in snap and apt? I really do not like snap.
    I hope this makes sense, but I'm not sure of it.
    Running kde neon 5.27, kernel 6.5.0-15-generic (64-bit).
    Maybe this is useful:
    $ snap list
    Name Version Rev Tracking Publisher Notes
    bare 1.0 5 latest/stable canonical base
    chromium 121.0.6167.139 2742 latest/stable canonical -
    core20 20231123 2105 latest/stable canonical base
    core22 20231123 1033 latest/stable canonical base
    cups 2.4.7-3 1024 latest/stable openprinting -
    gnome-3-38-2004 0+git.efb213a 143 latest/stable canonical -
    gnome-42-2204 0+git.ff35a85 141 latest/stable canonical -
    gtk-common-themes 0.1-81-g442e511 1535 latest/stable canonical -
    kf5-5-110-qt-5-15-11-core22 5.110 3 latest/stable kde -
    snapd 2.61.1 20671 latest/stable canonical snapd
    No skanlite in there.
      Did you sudo snap remove --purge skanlite?
      Without --purge snapd caches the removed Snap somehow (I don't know enough about the exact process to determine if this could have led to your situation, but I think it is a possibility).
      PS: FWIW Skanlite (installed with apt) works without any problems here both in Kubuntu 22.04 and TUXEDO OS (similar to KDE neon).
        yes, apt packages (debs) and snaps or flatpaks are completely separate application binaries/etc
        The snap works fine for me here, no d-bus errors, though the first review I see for skanlite in Discover is that error. lol
        $ skanlite
        Try rebooting, or using the menu icon to launch it. For some reason bash is looking in /snap/bin/foo before other locations in the hierarchy, or there is some caching going on?
        ~$ echo $PATH
        /home/mee3ee/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/home/mee3ee/.
        local/bin:/home/mee3ee/stl/prefix
        Snap is nearly at the end , and would be looked at almost last here. I do see this, but rebooted after a kernel update on this machine, and all was fine after.
        There probably is a way to force a refresh of this, but the reboot time was less than it would take to find the answer.
        ...../Which should have been obvious to me, once I did look: open a new terminal window instead of using the open one (which starts with a new empty "memory"), or using the command hash -r to clear this manually.
        So....much as we will all jump on and blame Snap, it isn't a Snap issue here at all, in this case, just normal bash shell stuff.
        The d-bus one, I dunno, since I don't see it, on two different machines, and I need to climb out of the rabbit hole and go back to working hehe
          Opening a new window and entering skanlite on the CL worked. After that, it also works from the launcher.
          Many thanks.
