Regularly (a few times a day) I no longer have network wifi connectivity when using KDE neon on an HP elitebook laptop.
I use a low latency kernel because I use midi musical instruments
Any ideas on what could cause this and how to solve it ?
I have a dual boot W7 - KDE Neon, and I never experience this on W7 (I dont use it very often though)
At the same time other devices connected to the lan are working fine (I can watch youtube on my tv and my daughter has no problems on her laptop), so it is not a router problem.
I cannot ping my router anymore
marc@HPT:~$ ping -i 1 192.168.1.1
connect: Network is unreachable
when I look at the network with ifconfig, I see that my IPv4 IP address has gone and I only have an IPv6 address.
wlo1 Link encap:Ethernet HWaddr 6c:88:14:ab:aa:70
inet6 addr: fe80::6e88:14ff:feab:aa70/64 Scope:Link
inet6 addr: 2a02:1811:1412:1100:6e88:14ff:feab:aa70/64 Scope:Global
inet6 addr: 2a02:1811:1412:1100:3ca3:cc0a:9605:a4eb/64 Scope:Global
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:55936 errors:0 dropped:0 overruns:0 frame:0
TX packets:28141 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:49888625 (49.8 MB) TX bytes:5147411 (5.1 MB)
When I disconnect and reconnect wifi using the network icon in the system tray, everything works normal again
inet addr:192.168.1.247 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::11d2:3d67:ef41:ed9a/64 Scope:Link
inet6 addr: 2a02:1811:1412:1100:c40a:696d:eb7b:4f03/64 Scope:Global
RX packets:165743 errors:0 dropped:0 overruns:0 frame:0
TX packets:87374 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:211369670 (211.3 MB) TX bytes:11164765 (11.1 MB)
PING 192.168.1.1 (192.168.1.1) 56(84) bytes of data.
64 bytes from 192.168.1.1: icmp_seq=1 ttl=64 time=1.68 ms
lshw output
*-pci:4
description: PCI bridge
product: 7 Series/C210 Series Chipset Family PCI Express Root Port 4
vendor: Intel Corporation
physical id: 1c.3
bus info: pci@0000:00:1c.3
version: c4
width: 32 bits
clock: 33MHz
capabilities: pci normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:29 memory:d4000000-d40fffff
*-network
description: Wireless interface
product: Centrino Advanced-N 6205 [Taylor Peak]
physical id: 0
bus info: pci@0000:25:00.0
logical name: wlo1
version: 34
serial: 6c:88:14:ab:aa:70
width: 64 bits
clock: 33MHz
capabilities: bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=iwlwifi driverversion=4.13.0-37-lowlatency firmware=18.168.6.1 ip=192.168.1.247 latency=0 link=yes multicast=yes wireless=IEEE 802.11
resources: irq:35 memory:d4000000-d4001fff
lshw output
*-pci:4
physical id: 1c.3
version: c4
width: 32 bits
clock: 33MHz
*-network
physical id: 0
logical name: wlo1
version: 34
width: 64 bits
clock: 33MHz
