Fully updated KDE neon 5.27, User's Edition, Wi-Fi issue
    Folks,
    "Enable Wi-Fi" box checked in tray panel icon's right click, but it dos not hold . It is annoying that on every start-up, one has to check the box for connection.
    Any way to fix this issue?
    Thank you!​
    Right-click the wifi icon in the tray panel and click on Configure Network Connections...
    Select/highlight your Wi-Fi entry.
    In the General configuration tab, ensure that All users may connect to this network is checked.
      In the General configuration tab, ensure that All users may connect to this network is checked.​
      It does not work! I had already tried this and played around with some other option e. g. setting higher priority, changing user in the "Advance" option, to no avail, before posting here.
      As i mentioned in my OP, its only an annoying task at every start-up, I can live with that.
      Thank you!
        Of course, knowing information about the device might help.
        It might be a known bug in its driver for some people.
        It most likely is not related to KDE/Plasma, or a setting that it can apply itself, unless it does not act the same in Ubuntu or other Flavour.
        lspci -v | egrep -i 'wifi|wlan|wireless|wi-fi'
        or
        lshw -C network
        Or poke around Kinfocenter and copy relevant text:
          marco@t540p:~$ lspci -v | egrep -i 'wifi|wlan|wireless|wi-fi'
          04:00.0 Network controller: Intel Corporation Wireless 7260 (rev 83)
          Subsystem: Intel Corporation Dual Band Wireless-AC 7260
          Kernel driver in use: iwlwifi
          Kernel modules: iwlwifi
          marco@t540p:~$ lshw -C network
          *-network
          description: Ethernet interface
          product: Ethernet Connection I217-LM
          vendor: Intel Corporation
          physical id: 19
          bus info: pci@0000:00:19.0
          logical name: enp0s25
          version: 04
          serial: 3c:97:0e:f0:1d:1e
          capacity: 1Gbit/s
          width: 32 bits
          clock: 33MHz
          capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
          configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=5.19.0-41-generic firmware=0.13-3 latency=0 link=no multicast=yes port=twisted pair
          resources: irq:28 memory:f4600000-f461ffff memory:f463f000-f463ffff ioport:5080(size=32)
          *-network
          description: Wireless interface
          product: Wireless 7260
          physical id: 0
          bus info: pci@0000:04:00.0
          logical name: wlp4s0
          version: 83
          serial: 7c:7a:91:2e:6e:fe
          width: 64 bits
          clock: 33MHz
          capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
          configuration: broadcast=yes driver=iwlwifi driverversion=5.19.0-41-generic firmware=17.3216344376.0 7260-17.ucode ip=192.168.1.81 latency=0 link=yes multicast=yes wireless=IEEE 802.11
          resources: irq:34 memory:f4400000-f4401fff
          PCI
          Flags: bus master, fast devsel, latency 0, IRQ 34
          Memory at f4400000 (64-bit, non-prefetchable) [size=8K]
          Capabilities: <access denied>
          Kernel modules: iwlwifi​
          FYI, I have both Kubuntu 22.04, and Ubuntu 24.04 on other partitions in the same laptop, Lenovo T540p. These both function properly.
