Hello everybody,
yesterday I installed KDE Neon and I am quite happy with it.
However, there is one thing I wonder about: During the installation process I've chosen the option of manually partitioning because the installer suggested a swap partition >15 GiB. At first I created the EFI parition, then the root one and last but not least the swap partition with a more reasonable size of 2 GiB.
As far as I can tell, the installation went fine. But when I checked the partitions in the installed system, I've noticed that the root partition occupied sda1, although I've created the efi partition first. To be fair, I've checked the partitions once again in Calamares before continuing via the "Change" button at the partitioning step to check whether I've set the right flags for the partitions. But this button did not say "Shuffle".
lsblk:
Do you have any idea why this could have happened? As far as I am aware, this should be a valid partitioning scheme, right?
Best regards,
Fabian
Additional information:
lsblk:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS sda 8:0 0 238,5G 0 disk ├─sda1 8:1 0 236G 0 part / ├─sda2 8:2 0 512M 0 part /boot/efi └─sda3 8:3 0 2G 0 part [SWAP]
Best regards,
Fabian
Operating System: KDE neon 5.27 KDE Plasma Version: 5.27.3 KDE Frameworks Version: 5.104.0 Qt Version: 5.15.8 Kernel Version: 5.19.0-35-generic (64-bit) Graphics Platform: X11 Processors: 4 × Intel® Core™ i7-6500U CPU @ 2.50GHz Memory: 15.5 GiB of RAM Graphics Processor: Mesa Intel® HD Graphics 520 Manufacturer: HP Product Name: HP EliteBook 820 G3 zz0.4xgxtm8o5fuzz
