Kontact Still Not Working Properly
    [SOLVED] Kontact Still Not Working Properly
    I have neon installed on another Laptop and I have decided to have another go at getting Kontact to work. My calendar file is 394.8 KiB in size and when I try to merge it with the current calendar there are several beeps and the desktop is frozen.
    I reduced the file size to 124.6 KiB and the same thing happened. Also, when I try to add a New Event I get an error message that it failed to append item. As well as this problem, time of an event is always set to PM. An AM time cannot be set.
    I should point out that this calendar works as it should on Yakkety.
    I have now had another go at trying to get Kontact to work and I am glad to report that it now works as it should. I have been able to import my calendar into the existing blank calendar and I was able to add new events.
