Antone else tried "kio-gdrive" ? Stuck in endless log-in loop
    [SOLVED] Antone else tried "kio-gdrive" ? Stuck in endless log-in loop
    Found a new way to access your google drive - kio-gdrive. It's in the repos. But it's not working here. I've tried to open it several times and it keep endlessly asking me for my gmail password, Specifically;
    I attempt to open my gdrive with Dolphin,
    a google log in dialog opens to ask for my google account info,
    it accepts my input,
    it returns to the google log in dialog.
    Opening Dolphin from konsole and trying, I get this error:
    [FONT=monospace][COLOR=#000000]Cannot creat accessible child interface for object:  PlacesView(0x1643000)  index:  44[/COLOR]
    org.kde.kurifilter-ikws: "gdrive://" : QUrl("gdrive://") , type = 0
    Trying to convert empty KLocalizedString to QString.
    [/FONT]
    I'm curious if anyone else has tried using this.
    Do you have the KWallet enabled ?
    Bug 373402 - kio-gdrive keeps asking for authentication if kwallet is not available : https://bugs.kde.org/show_bug.cgi?id=373402
    Before you edit, BACKUP !
    Why there are dead links ?
    2. Thread: Lost Information
      Rog, thanks for the hint. I have kwallet installed but it was missing a library. Apparently, KDEneon devs did not want kwallet installed by default, but it is - just without libkf5wallet-bin which allows it to work with QT5 I guess. Installing the lib file and launching kwallmanager allowed me to have a wallet and viola! Thanks again.
        I was using it ,,,,but for about 3 weeks or so I get this when trying to access it ,,,,,,,,,,,,,,
        launching dolphin from a Konsole I get NO error or other output ,,,,except the initial startup.
          Have you checked your path? Mine shows three slashes between gdrive and my email - seemed odd to me:
          gdrive:///stuartksmith@gmail.com
            no mine is 1 slash ,,,,I will try 3 .
              no , no difference
                I just dont get it ,,,,,,"kio" dose my google photos through Gwenview's "export to google photos" ,,,,,,,that should be quite similar.
