I was in the middle of installing new package and got this error :
sudo apt-get install kompozer
Reading package lists... Done
Building dependency tree
You might want to run `apt-get -f install' to correct these:
xubuntu-desktop: Depends: foomatic-db-engine but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
The foomatic-db-engine package can not be fixed by any means, it just stuck there preventing me from installing anything else >
![Sad](https://www.kubuntuforums.net/core/images/smilies/sad.gif)
