Problem with desk top icons
    [SOLVED] Problem with desk top icons
    Not sure I'm using the right terms here.
    I created a number of icons on the desk top to run a number of applications
    When I click on a particular icon it takes on all the properties of another icon.
    Kubuntu 18.04
    Any help would be appreciated.
    This might help.
    The desktop icons were created by:-
    Right click on the desktop and select 'Create New/Link to application'
      OK, I can mark this as solved because its stopped happening - don't know why
        The magic of Linux!
          Did the humidity in your region increase? If it did then electronic gremlins die!
