I'm a new Kubuntu 18.04.2 desktop AMD64 user. I've installed krfb to allow remoting into desktop from Mobaterm running on Windows 10. Everything seems to work fine except the "<" key displays the ">" key when pressed. On the local Kubuntu monitor the key works. The problem occurs both inside a console terminal window or inside a GUI program such as Kate of Visual Studio Code. I've also tried RealVNC and UltraVNC client programs on Windows, but they have the same problem.
I've researched the problem and there are reports of problems with VNC that are corrected by putting "export XKB_DEFAULT_RULES=base" in the xstartup file. Does krfb use an xstartup file and if so where is it?
In the Settings + Hardware + Input Devices + Keyboard the "Keyboard model" is set to Generic | Generic 101-key PC. I've also tried Generic 104-key PC but that does not solve the problem.
Any ideas?
Any ideas?
