newbieeeee help.....
i have used some different versions of linux versions on my machine and
they worked perfectly well.......... ,, but ever since my motherboard came
back after repairing there seems same kind of problem occur with every
linux distro i try to install on my pc ... the resolution size doesnt go beyond 600x800 pixels ... .... there is no option present for that ........
windows 7 run perfectly on 1900x1024 resolution on my 22' monitor but linux versions dont give the option to run it over 600x800rsolutions .. my pc specs are :--
CPU == Core 2 Quad 2.40 GHz
RAM == 3 GB
GPU == intel integrated 286 mb graphics memory
bios == intel before repair it was american metagrands
i m currently running kubuntu9.04
these thins i have tried :--
xrandr --output VGA1 --auto //nothing happened
lspci | grep VGA
00:02.0 VGA compatible controller: Intel Corporation 82G33/G31 Express Integrated Graphics Controller (rev 10)
i can't find any third party hardware drivers for the same ... if u know please help .,... plus usr/bin/jockey-kde crashes every time i search for any propetary driver
any help will be appreciated .... this resolution shatters my hope of good display on my 22' monitor please anyone help
RAM == 3 GB
lspci | grep VGA
