Preface: I'm currently living in an electromagnetic black hole of a place, far, far away from any landlines and such.
Even mobile coverage was nonexistent - at first. I managed it with antennas and amplifiers... it wasn't easy but I did. WiMax companies gave up. I didn't :-)
So I have internet access. With a mobile phone hotspot. At times it's really fast, at others... less.
Thing is, it seems to have nothing to do with signal strength - which does vary a bit, but there really seems to be no correlation.... and thing is, actual bandwidth is not the problem. It's response times.
When it goes "slowish", it just takes ages (seconds, actually, but, you know ;-) to connect to the site, after which, it's mainly fine.
Thing is, If I use a VPN, regardless of country, it's pretty much always fast. There's no connection delay.
Those delays, when not VPNnning, are pretty random, but they're there often enough. On VPN, they're never there. It's always fast.
I can't find a reasonable explanation for this. Any ideas?
"And it's only the giving that makes you what you are" -- Jethro Tull, Wond'ring aloud.
