So I get home yesterday open the lid on my system76 Bonox8 and start checking emails .
Within 5 min the shutdown screen pops up and the box shuts down.
I'm like , what the heck , and try to restart the box by pressing the power switch , the caps lock and number lock lights both start flashing and a lowed beep , beep , beep continuously going off , hold down the power button and leave it off for a wile .
5-10 min latter I start it back up boot to a different install just in case and start reading emails .
Again with no warning the shutdown screen and power off and again the beeping if trying to immediately restart .
Now I'm getting worried and think hay I don't think I heard the fans running (they have been a bit noisy).
So I get myself ready for a trip inside the box .
remove back panel and ,,,, the Nvidia GPU fan will hardly spin ,
, I have no money at the moment to spend on this ,,,so lets extract it and see if we can repair it , i could pull the fan off the armature and their was a buildup of dust inside the magnetic ring , a few qtips later and it was clean enough to spin but still a bit draggy , some extra virgin olive oil on a qtip rubed on the central shaft that holds the fan centered in the armature and it spins nicely .
Now my thinking on keeping the fans blown out was a tad off , i assumed that one could just blow air through the air intake in the bottom of the case and it would help , but these fans are closed on the sides except for a bit in the center and directs the air flow out the 1 flat SIDE of the fan case and across a radiator looking stile heat sink it's pressed up against ,
the hole end of the slot that presses on the heat sink was clogged with dust 1/8th of an inch thick .
clean it all up reinstall it and do the same for the CPU fan except it is one of the type that the fan dose not pull off , but it was still spinning well .
now the box is running quieter cooler than ever , go figure .
I guess I better start looking into how to get some replacement fans on hand for the inevitable .
So keep in mind all my linux friends just because the air passages on the outside of the case look clean dose not always mean things are well , their was also a cluster of solder dots (transistors resistors or the like) on the MB right under the GPU fan that was blackened over with dust that I had the gently rub away with a qtip
