Hey everyone.. Ok i was playing around with VirtualBox in a kubuntu host with a separate Kubuntu 24.10 guest. After the install it was freezing and glitching despite trying numerous "Fixes" i found online.
After playing with it and messing around for a while i noticed that downloading and changing the default theme seems to have fixed the issue.
If anyone else is having similar problems you could perhaps try this.
Let me know if it helps.
