Enjoy Monitoring Mantic Kubuntu 23.10
    Sounds like you ran into a GRUB problem not a BTRFS problem. If OS-prober didn't find your EXT4 Kubuntu install, I don't see how that could be the fault of the file system format.
    BTW, wow, nine partitions - old school, lol.
    If you decide to attempt BTRFS again, you only need a single partition for it. The installer will separate root from home using subvolumes on a single file system partition. With all the testing you like to do with these pre-releases I would think BTRFS would be a given. Snapshots and roll-backs would be a huge benefit.
      Sorry for the confusion as the graphic of the KDE Partition Manager was for my system when it was working with the ext4 format for all Root partitions. When I had my Root partition formatted with brrfs, only the latest Kubuntu installation showed on the boot menu. The other did not show and the only way to see if it was still present was to use Dolphin to see what was gong on.
      BTW the number of partitions is mainly due to my attempt to minimise the size of the Windows 10 partition which was using all of my Disk.
        Following your comments, I have tidied up my partitions, however I still have the old world partitions of 6 associated with Mantic, Lunar and efi and 3 related to Windows.
        Unfortunately, I am not convinced about the advantages of rollbacks as it would take up more disk space. I cannot see any advantage in btrfs formatting for the root partition as the partitions for Linux distributions always give access t previous kernels to boot with if problems arise. I am quite happy to have my Home partitions formatted as btrfs.
        For the problem that I consider to be related to grub and btrfs, I decided to try different combinations of Mantic and Lunar with btrfs and ext4. I use update-grub to find the partitions after this process. In all cases my Windows and efi partitions are always listed. The table below shows the results of this process for the Linux distributions using update-grub to find the partitions.
        Mantic Ext4 Root Lunar Ext4 Root
        Mantic & Lunar Listed Lunar & Mantic Listed
        Mantic Ext4 Root Lunar Btrfs Root
        Mantic Only
        Boot time about 10 times slower
        with Kernel of Lunar
        Mantic Btrfs Root Lunar Btrfs Root
        Mantic only listed no access to Lunar Not Listed and not visible
        As you can see the btrfs on both Root partitions works if you only have one Linux distribution on your system. However if you have more than one, the last installed Linux distribution is only seen and accessible. From the table above, having one with btrfs and the other with ext4 does not work very well. The access to multiple Linux distributions with the old world formatting works only when both Root systems ext4 formatted.
          Thank you for this experiment with GRUB/os-prober (I think that is what is technically responsible for identifying other partitions with operating systems when you use update-grub) and the table.
          To be honest I don't understand the table and its labels, though (fstab?)…
          Edit: Now I do - thank you for the corrections.
            That's not quite the case.
            Not much, and even less if you don't hoard them I use Timeshift to create, restore, schedule, delete, and browse the content of the snapshots.
            Snapshots are essentially just the changes, not full-system backups or anything like that.
            Nothing changes here at all, or isn't supposed to. But then again, your system is more complex. I think your issues are from having multiple *buntu installs sharing the same EFI partition.
            Normally, each OS install has its own separate boot loader, so you would have individual grub installs for each one, with the Grub seen at boot by default being the one set in your BiOS.
            *buntu don't have separate grubs, so Kubuntu/Ubuntu/Xubuntu installs all use the same exact files, names and dirs in that EFI partition, since they are actually the same OS. So if you have Lunar installed, then install Mantic, Mantic's grub files replace/overwrite the existing Lunar grub in the EFI partition, and so on. This has zero to do with btrfs since the boot files are on that Fat32 EFI partition.
            otherwise, I can't explain why you see differences, though that is possibly an issue of everything, including grub, being in a 'volatile' state at any given moment in Mantic at the moment
            Jlittle has some experience in dealing with this area, hopefully he can give hints.
            A separate drive is ideal for this, as you can have multiple EFI partitions, and thus keep Lunar and Mantic's grub installs from overwriting each other. But that isn't always feasible or possible for everyone.
            That is more than enough reason to continue doing so. We just are offering a suggestion that is 5000% ideal for a testing sort of scenario.
              Jlittle has some experience in dealing with this area...
              I advocate for the idea of taking control of the boot, by installing grub by itself, independent of any install. I have to maintain grub myself, but this is easy and very simple. I also have to know what to change in /etc/fstab, but again this is easy and simple. The hardest part has been to stop installs messing with it. Kubuntu has been good for this because ubiquity can be run with the "-b" switch to not install a boot loader.
              Well put.
              One may want to test the whole install process, including that of the boot loader. But IMO that's not very useful if tracking a new release, especially when the iso changes daily.
                I must say that I have been using my Sacrificial Laptop to test ideas. I have created two system partitions (ie 4) to test two Linux installations. I did try Linux Mint with btrfs Root partition and then with an Ext4 Root partition. In both cases, LM was the only one showing. I have just reinstalled Mantic and after doing this I could see Linux Mint.
                From what you are saying, I believe that I would have to use my Mantic installation and copy the grub boot menu to a different location and then modify the location of the new boot menu and then reboot to check that Manitc can be booted with this new location. Following this I would have to install the other distribution with ubiquity -b option and then edit the grub boot menu with the location of the boot menu.
                I must say that this sounds fairly involved and much more difficult than just formatting the Root partition as Ext4 for both installations which I know works very well at locating all distributions as well as giving the option to format the boot menu with grub-customizer. I find this option essential for my main laptop because of its 4K display. However on my Sacrificial Laptop this problem does not exist.
                  It is now 3 months to go before the release of Mantic Minotaur.
                  Mantic updates are continuing at a great pace and we are now at the half way development point. Mantic continues to be incredibly stable and a continuing tribute to the capability of the developers.
                  Mantic’s advances over the last month are illustrated in the table below.
                  4 Months to go 3 Months to go
                  KDE Plasma Version 5.27.5 5.27.6
                  KDE Frameworks Version 5.107.0 5.108.0
                  KDE Applications Version 23.04.2 23.04.3
                  QT Version 5.15.8 5.15.10
                  Kernel Version 6.2.0-21-generic 6.3.0-07-generic
                  You will know see that every key topic of development has been advanced in the last month. Of particular interest is the QT Version which is now at 5.15.10. I will be interested to see when QT 6 is released and this will herald the inclusion of KDE Plasma Version 6 which is either at the end of this year or early next year.
                  Finally once again, well done developers on a superb job at advancing Karmic!​
                    Thanks.
                    Qt 6 already has been released for a while (the current version is 6.5.x) - but Plasma 5.27.x et al. still use Qt 5.
                    If you search for installed Qt packages you can see that only a few Qt 6 packages are installed by default yet.
                      I realize that Mantic is just over half way in its development, but Muon still has problems on Mantic. When I go to Settings > Configure Software Sources, enter the required password and then select Other Software, the only listing on this is cdrom(Kubuntu 23.10 . . . . .
                      I would like to see the other packages listed so that, if I want to remove any, I can do so very easily. I just hope this is not too much to ask at this stage.
                        I don't think that Muon is developed anymore ("Archived project!"): https://invent.kde.org/system/muon
                          Maybe Launchpad may have some say in further bug fixing. I think this site is encouraging: https://launchpad.net/ubuntu/+source/muon
                            You are right - they seem to work on Muon there from time to time (but it seems to have been in a kind of "maintenance mode" for some time now and I wouldn't rely on it…): https://launchpad.net/ubuntu/+source...5.8.0-2ubuntu1
                              Note that Software Sources is not actually part of Muon, but a separate applet, also accessible from Discover, and shared with Lubuntu. iirc it also accessible from Synaptic as well. The package is software-properties-qt, and is a brother to the same exact python program used in Ubuntu.
                              This bug likely will be fixed --assuming that people report it on the bug trackers in case they don't notice (hint hint nudge nudge)
                              Yes, muon isn't really being maintained, not for ages. Note that the last release for this was in 2018. Any "dev" work done are packaging tweaks so that it builds and installs correctly, etc, and probably language edits. There has been no change in the actual code in over 5 years.
                              The is always Synaptic.
                                This bug likely will be fixed --assuming that people report it on the bug trackers in case they don't notice (hint hint nudge nudge)[…]
                                At least it is already part of the changelog on Lauchpad:
                                "Provide a compatibility symlink so Muon can still launch software-properties.​"
