How 3Blue1Brown does math animation
    For all you math lovers and teachers out there!
    Since I already had a python3 environmental setup using pip3 I decided to install Manium.
    It went smoothly. Had to upgrade a couple of modules but that went OK too. Now to play with it.
    sudo apt install libcairo2-dev libpango1.0-dev ffmpeg
    pip3 install manim
    pip3 check
    pip3 install --upgrade pygments
    pip3 check
    pip3 install testresources
    pip3 check
    pip3 install wurlitzer
    pip3 check
    pip3 list
    echo $PATH
    PATH=$PATH:/home/jerry/.local/bin
    pip3 check
