Vulnerability Prompts Warning: Stop Using Netgear WiFi Routers
    https://www.kb.cert.org/vuls/id/582384
    Firmware version 1.0.7.2_1.1.93 (and possibly earlier) for the R7000 and version 1.0.1.6_1.0.4 (and possibly earlier) for the R6400 are known to contain the arbitrary command injection vulnerability. CERT cited "community reports" that indicate the R8000, firmware version 1.0.3.4_1.1.2, is also vulnerable... The flaw was found in new firmware that runs the Netgear R7000 and R6400 routers. Other models and firmware versions may also be affected, including the R8000 router, CMU CERT warned.
