I bought a Lasko oscillating ceramic heater and plugged it into a surge protector. When I used it for the first time this morning, it ran for a few hours with no issues. Tonight, however, after only about 20-30 minutes, it tripped the surge protector. According to its user manual:
So the fact that what's described above did NOT happen, and instead the surge protector got tripped, what should I make of this? Do I need an electrician...again? (I recently had a major rewiring job done to put in a dedicated 208-230V line for a 24,500 BTU window A/C unit.) Can I plug the heater into the outlet that's for the A/C unit? Should I return the heater? WHAT WHAT WHAT??!!
SAFETY FEATURE
1. A thermal overload protector is built in to prevent overheating.
2. If an overheat temperature is reached, the Heater will automatically shut off. It can only resume operation when
the user resets the unit.
To Reset Heater:
1. Unplug the Heater and wait 10 minutes for the Heater to
cool down.
2. After the Heater has cooled down, plug the unit into a 120V~ electrical outlet and follow the operation instructions described in this manual.
To Reset Heater:
cool down.
![Confused](https://www.kubuntuforums.net/core/images/smilies/confused.png)
![Huh](https://www.kubuntuforums.net/core/images/smilies/huh.gif)
![ROFL](https://www.kubuntuforums.net/core/images/smilies/roflanimated.gif)
